The Mad Dash begins...
Re: The Mad Dash begins...
Postby mikeschn » Tue Aug 11, 2015 7:02 am
dales133 wrote:
This build is lightning fast and a seriouly cool looking camper
Thanks Dale!!! :)
GPW wrote::thumbsup: This one is going to be Light !!! 8)
I agree Glenn! :thumbsup:
capnTelescope wrote: Can't wait to see what he does in the galley.
Galley? There's going to be a galley? Oh yea, I'll build a piece of furniture which I'll slide in and attach to the floor. It'll probably slide in the door and get pushed rearward, and it might have to be built in 2 pieces! :?
KCStudly wrote:Almost done! Zowie, you are moving along quickly! :thumbsup: ... and with no sign of compromise in quality. :applause:
Wowers, I'll probably never be able to build that fast again!
Postby eaglesdare » Tue Aug 11, 2015 12:54 pm
Mike what made you decide to do another foamie?
I do love your new one also. Your work is really good. :wine:
Louella
May the foam be with you.
eaglesdare
Postby mikeschn » Tue Aug 11, 2015 5:51 pm
Weight mostly. I want to be able to make mad dashes across the country, and didn't want to haul around a heavy trailer. Plus I wanted a quick build this time, AND I wanted to try foam one more time.
eaglesdare wrote:Mike what made you decide to do another foamie?
Postby mikeschn » Tue Aug 11, 2015 6:06 pm
Came home tonight, and decided to play on the foamie, because we couldn't do anything yesterday.
So we skinned another section of the ceiling
and trimmed the outside edges, the window and roof vent hole
I also put putty in the holes in the side of the hatch, and the side of the body. I'm really curious to see how it sands out of canvas. :frightened:
That's enough for one night. I really should go out and try sanding, but I've run out of time... and it started raining...
P.S. I'm thinking about de-rating the axle now... removing 1 leaf should do it, right? I'm thinking the trailer will be around 500 pounds.
P.P.S. Just double checking my schedule... Here's what's on the agenda for this weekend...
Aug 15 & 16
Canvas Body
We are doing good for that item. I'm hoping to get some TBII on there as well, and maybe with a little luck, some garage floor paint! :NC
Postby redwing1967 » Tue Aug 11, 2015 7:00 pm
Looking really good Mike. Can't wait to see it in person.
Honestly after seeing all of these wonderful foamie builds, I just can't imagine wanting to build any other way. They're light, durable, weatherproof (if built right), and the styles are limited only by the imagination. The ONLY reason I could see wanting to build with wood is to make a "pretty" build. But the headaches that go along with that just don't add up for me.
In fact with a little more effort these really can be pretty. I keep looking at AKSNOWRYDER's Pico Light Foam build and that turned out beautiful....like it came off of the show room floor. 8) In fact my first build will be based off of that one...except slightly bigger.
Well done all and thanks for being the leaders in the foamie revolution. :thumbsup:
Romans 1:16 "For I am not ashamed of the gospel, because it is the power of God that brings salvation to everyone who believes: first to the Jew, then to the Gentile." (NIV)
redwing1967
Postby mikeschn » Tue Aug 11, 2015 7:59 pm
Yep, you're right. That is a really nice build. See ya this weekend...
redwing1967 wrote:Looking really good Mike. Can't wait to see it in person.
Postby tsmyth » Wed Aug 12, 2015 5:22 am
You have a lot of patience as showing in the details. I would like to know what the ROCKHOPPER weighed. I like your design and could not find the total weight in your writings.
tsmyth
Images: 28
Postby tac422 » Wed Aug 12, 2015 6:06 am
mikeschn wrote:P.S. I'm thinking about de-rating the axle now... removing 1 leaf should do it, right? I'm thinking the trailer will be around 500 pounds. :NC
Hi Mike,
Your build is looking great ! Glad to see you working in foam again. :D
I am curious to see if you end up at 500 lbs....
I'm thinking it will heavier than that, based on the Big Pink weight. I know I have a lot of heavy stuff in it, (fridge, AC, etc), but I think you'll be closer to 650 lbs. :thinking:
tac422
Postby mikeschn » Wed Aug 12, 2015 7:43 pm
Hatch dry fitted...
Hatch Prop v 1.0 tested...
Postby GPW » Thu Aug 13, 2015 5:12 am
NICE hatch !!! :thumbsup: 8)
Postby mikeschn » Thu Aug 13, 2015 7:24 am
Hey guys,
I'm wondering if that gray garage floor paint is really the right color for this. Maybe a silver metallic to match the TV would be better? Any idea where I can get a silver metallic paint that would work on the outside of this?
Postby GPW » Thu Aug 13, 2015 8:27 am
A Silver Metallic ENAMEL would likely work over Foam , the enamel reducer doesn’t seem to bother the foam ... (as always test on scrap first) ... ;)
I’d think the old Aluminum paint would be Good (enamel) as it would look like the vintage trailers , and blend in , providing a real metal protective layer from UV , and no one even guessing it was a Foamie ... :thumbsup: 8) :D I love the old look, Silver with a red stripe ... perfect for TD, and easy ... 8)
Postby Mary C » Thu Aug 13, 2015 11:46 am
Mike after doing a lot of test with combinations of gripper and canvas and exterior paint. I decided to give my next one a thick coat of gripper then sand then another coat sand then exterior paint. I really like the way that test turned out. You want it nice for the wife. ;)
Mary C
Mary C
Images: 473
Postby mikeschn » Thu Aug 13, 2015 6:40 pm
Here's a better shot of hatch v 1.0
And here's a better shot of the hatch closed... but alas, the first time I dropped the hatch, all the spackling came flying out of the joints. So I've filled the joints with gg, and plan on sanding it first thing in the morning.
Postby tac422 » Thu Aug 13, 2015 6:43 pm
Mike,
I used this aluminum paint over Gripper ...
It turned out really nice.
111629 112391
tac422
