two doors or just one? Again, I’ll be alone most of the time.
Galley and cabin storage – I’ve seen a lot a wonderful cabinet work in a lot of the builds here. But I’m not a cabinet-maker. Could I get by with a simple counter and a couple of shelves? And simple shelves for cabin storage? Looks like a place to save a lot of fabrication time.
Finishing – Varnish, paint, or aluminum-clad?
tony.latham wrote:Wrenchbender:two doors or just one? Again, I’ll be alone most of the time.
Two. End of discussion. If the wife gets in there once, and you've got one door, it's not going to work. Besides, two doors means two windows. You really need the ventilation. (Yeah, I know, you could put a window on that side.)
Factory doors are expensive. I'm happy with mine. I've put them in three teardrops, and when I did it, the thought that went through my brain––six times–– was, "that was easy." Building doors is labor intensive, or so I've read. Add up hinges, latches, trim and windows and you'll see what a DIY door costs. I think TC Teardrops sells doors a bit less than Vintage does. (I'm fine with the Vintage doors BTW. The big smoked glass windows is a nice feature.)
Simple is functional. Take a look at my interior, the bottom shelf is an extension of the galley counter. The 3" lips work great and everything is easy to find:
Take a look at this thread: viewtopic.php?f=50&t=61738 and you'll see a similar interior.
I put sliders up front under a shelf. You need the shelf to "put stuff" like books, glasses or whatever:
My galley is relatively simple. The angled drawer is a challenge, but you could make it with a 90º face, too.
Five wide? Yes, but on a four-wide trailer? It's been done but there are tradeoffs that it sounds like you understand. Northern Tool sells a 5-wide trailer.
A well sealed aluminum-clad teardrop isn't afraid of years in the sun. I don't know anything else that'll do that.
Yep, there's choices though.![]()
bobhenry wrote:I place my air conditioner UNDER the camper in the shade and duct the cold air only into a duct I designed for that purpose however an open window will work also.
