tony.latham wrote:I'd suggest you get a copy of Fredrick's Teardrop Builder's ShopManual. It's about 250 pages with lots of photos.
http://www.campingclassics.com/shopman05.html
jonw wrote:I used solid 5/8in. marine plywood for my walls and .040 aluminum for the roof (floating, attached only at the edges underneath side and bottom molding). My spars were 1x2 poplar (whose actual dimensions are 3/4 x 1 1/2in).
Because they would be exposed (my exterior was not covered with anything) I didn't want to drill thru the wall into the end of the spars. But also because that is a very weak joint that will cause the wood to split over time.
Instead I used Kreg pocket screws and glue to attach the ends of the spars to the plywood. No end grain on either the ply nor the poplar to weaken and split. Has held up fine for 4+ years so far and I wouldn't hesitate to use this method again under the same circumstances.
KCStudly wrote:My ceiling/spar to wall arrangement is similar to the Fredricks method (ceiling and spars attacth on top of wall). Rather than trying to hold the ceiling up to the spars or use temporary supports to keep the ceiling from sagging while attempting to attach it to the walls, I positioned and glued the spars to the top of the ceiling panel before installing the ceiling. Sort of a cross between the Fredricks method and how Aggie/Tom did his premade roof assembly.
I used some small temporary alignment tabs double tapped to the top of the ceiling to help locate the spars and keep them from sliding around in the glue; and a 2x4 beam and wedge shim arrangement clamped to the work bench to be able to clamp the spars fully out in the field of the panel (or you could use weights). This allowed me to avoid having any visible fasteners in the ceiling.
