Teardrop slide out
Teardrop slide out
Postby vitya-velik » Sun Oct 25, 2015 3:40 pm
Is it possible to build a teardrop slide out? If so how and with what material?
vitya-velik
Re: Teardrop slide out
Postby KennethW » Sun Oct 25, 2015 7:08 pm
A slide-out for what? sleeping, galley, bathroom, foot slide-out for sleeping sideways?
With a slide-out there is some set up. With a simple teardrop there is almost no setup required.
KennethW
Images: 82
Postby vitya-velik » Sun Oct 25, 2015 9:00 pm
KennethW wrote:A slide-out for what? sleeping, galley, bathroom, foot slide-out for sleeping sideways?
For sleeping or like reading a book.
vitya-velik
Postby vitya-velik » Sun Oct 25, 2015 9:04 pm
http://m.ebay.com/itm/FULTERER-FR5210-H ... nav=SEARCH
Will these drawer slides work? It says 200lb capacity. I weigh around 130.
vitya-velik
Postby dales133 » Sun Oct 25, 2015 9:05 pm
Unless you made it a poptop or extremely small i see no sense in making a slide out but this ones pretty cool
dales133
Postby vitya-velik » Sun Oct 25, 2015 9:21 pm
Yea that's where I got my idea from. So will the floor of the slide out sit on the main floor? I don't know how it will work.
vitya-velik
Postby dales133 » Sun Oct 25, 2015 9:28 pm
Yea it must either slide under or over the other.
Id use bearings if you were going to attempt it as it would be stronger than comercial slides
dales133
Postby vitya-velik » Sun Oct 25, 2015 9:47 pm
dales133 wrote:Yea it must either slide under or over the other.
Do you know where I could get those? And what about the back side of the slide out? Wouldn't it just sit in the middle of the camper vertically when the slide out is not in use?
vitya-velik
Postby dales133 » Sun Oct 25, 2015 9:56 pm
Im building 5 foot slide out draws at the moment but im only getting the parts together thus far.
Im using skateboard bearings but you might want to go a bit heavier if your putting all that weight on it.
By the looks of things the slideout on that one is the width of the actual cabin.
If you havnt built something like this before i recon it might be overly complex for a firs build
dales133
Postby vitya-velik » Sun Oct 25, 2015 10:40 pm
dales133 wrote:Im building 5 foot slide out draws at the moment but im only getting the parts together thus far.
I don't see how I can use skateboard bearing for a slide out?
vitya-velik
Postby dales133 » Sun Oct 25, 2015 10:41 pm
Have a look at my build thread.
Will answer your canvas question and tony posted a bearing slide picture on it
dales133
Postby razorback » Mon Oct 26, 2015 7:54 am
razorback
Postby backstrap bandit » Tue Nov 03, 2015 4:45 pm
Why not just mount some rollers on bottom of slide out the sides will guide it a flange type around inside of wall will stop it from being pulled out too far and a couple of bars under the slide will support it kinda like a pop up pull bars out let them hit the ground supports slide out
backstrap bandit
Images: 15
Postby garycg » Tue Nov 03, 2015 7:01 pm
Why was i requested to reply
garycg
