KennethW wrote:A slide-out for what? sleeping, galley, bathroom, foot slide-out for sleeping sideways?
With a slide-out there is some set up. With a simple teardrop there is almost no setup required.
dales133 wrote:Yea it must either slide under or over the other.
Id use bearings if you were going to attempt it as it would be stronger than comercial slides
dales133 wrote:Im building 5 foot slide out draws at the moment but im only getting the parts together thus far.
Im using skateboard bearings but you might want to go a bit heavier if your putting all that weight on it.
By the looks of things the slideout on that one is the width of the actual cabin.
If you havnt built something like this before i recon it might be overly complex for a firs build
