Ok I am seeking some advice.
I got to a dry fit of my ceiling and was very happy. All looking good.
- IMG_1268.jpg (31.77 KiB) Viewed 1199 times
I made a measuring mistake and I don't have enough space to fit in my insulation as planned. I am using Steve Fredericks method of doing the walls, ceiling & roof. I have place my spacers between the roofing spars in place and they are sitting about 4-5mm proud of the top of the wall. The building method would normally call for me to run along this edge with a belt sander to level them with the wall.
- IMG_1271.jpg (70.87 KiB) Viewed 1202 times
What I have done is not made the slot the ceiling fits big enough. It is only 20mm deep, it should have been 25mm. 25mm with a 4mm ceiling sheet left me 20mm for insulation and spars 20mm x 30mm in size. The 20mm with a 4mm ceiling sheet leaves me 15mm for insulation and spars 15mm x 30mm in size. I don't think the insulation comes in 15mm sheets but will have to check on Monday. 10 & 20mm only I think. So what I was thinking of doing was leaving the spacers at their height so I can fit 20mm of insulation in and make the spars that little bit bigger
- IMG_1275.jpg (34.11 KiB) Viewed 1202 times
The roof spars would also be trimmed to the correct size.
I would then have to fit the roof and use a router to trim it back to the sides. This would then leave me a gap of around 5mm around the side - which can be seen under my finger in the first photo.. I could then fill this with builders bog to make the side smooth.
This would then leave me with a problem with the hatch as the roof line back to the hatch would be raised slightly (4-5mm). I could then overcome this by placing two layers of ply on the outside of the hatch.
So, is it ok to use builders bog in this case?
Are spars 15mm x 36mm big enough if there is 15mm insulation available?
Do I gain anything by going to 20mm x 36mm spars if I can get 15mm insulation?
Can anyone see any other issues?
Edit: My roof spars are currently pine and measure 42mm x 38mm. I can put them through a thicknesses to make them 42mm x 15 or 20mm or have them 38mm x 15 or 20mm.
Thanks
Laurie
