Ira wrote:Heikki--I think it looks fantastic and that you're totally NUTS. Plus, what are you towing with?
If it's a visual thing, Fred's profile is a great one.
But do you think that getting in and out is going to be a major problem? If that's the case, a cosmetic solution won't cut it.
Classic Finn wrote:Good evening Alaska... Hows the weather up there way up North?
... so you may have to find an axle with a larger drop. If you can find an EU approved drop axle, that would be an easy fix (no cutting, welding required).Also its illegal here to set the axle over the leaf springs.. UGH!
Classic Finn wrote:Take a look at Uncle Dennys tear... the leafspring and what looks like a Torsion Axle to me on Top of Leaf Springs.?
Classic Finn wrote:Fred is that photo or drawing you showed one of your own?
That is cool.....I was just thinking of a cutout - half like circle near the axle part to the template and then lower the sides ..
Not much left on inside height then ? Or should we laminate plywood on to the existing ply to add height lost from dropping?
Do you have more info on that Tear?
