Door hinge question
Door hinge question
Postby dakotamouse » Sun Jun 11, 2006 10:21 pm
I'm looking through the Kuffel Creek plans and I just can't figure out what he uses for the door hinge. Is it the hurricane hinge only cut down?
I'm trying to figure out an order for lil bear parts. Should I be ordering 2 huricane hinges? One for the galley and one to cut in half for the two doors?
Where did you get it? We didn't get it, we built it!
Myron and Mary
dakotamouse
Titanium Donating Member
Images: 128
Postby Arne » Sun Jun 11, 2006 10:28 pm
a hurricane hinge needs a stop or it will just slide through... other than that, I do not know.. most use stainlless piano hinge. I got a 6 foot length from a marine place and cut it in half.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby dakotamouse » Sun Jun 11, 2006 10:37 pm
That makes sense. Thanks!
Myron and Mary
dakotamouse
Images: 128
Postby madjack » Mon Jun 12, 2006 12:51 am
Grant, also sells an offset piano hinge for the doors that many have used and liked...ask Doug Hodder about it for one
madjack 8)
Postby dakotamouse » Mon Jun 12, 2006 11:53 am
Dang! Missed that on the site. Looks like that would be the way to go. Thanks!
Myron and Mary
dakotamouse
Images: 128
Postby toypusher » Mon Jun 12, 2006 12:40 pm
If you are building a Cubby, then the parts list should tell you what you need for a hinge. I used a aluminum piano hinge (I think) that I got from RW Johnson.
toypusher
Images: 324
Postby asianflava » Mon Jun 12, 2006 1:12 pm
I have a set of Grant's offset hinges. I like them a lot, it makes the door installation really easy. The only problem is, he can't make them for you if your walls are really thick.
asianflava
Postby Ken A Hood » Mon Jun 12, 2006 1:22 pm
You could always get them formed for you, depending on the size.
STAINLESS-HINGES website
Disclaimer: I in no way resemble the avatar shown. Furthermore, I in no way have any affiliation to the Trailer Park Boys and more specifically Bubbles!
Ken A Hood
Images: 42
