WellsCargo 6x12.. 6" additional roof heigh & barns..
Re: WellsCargo 6x12.. 6" additional roof heigh & barns..
Postby ywhic » Tue Dec 15, 2015 6:57 pm
I Installed 1 1/2" vent pipe to the outside today.. also note the 30 amp RV inlet, blackwater valve, and new vent cover at almost 8 feet up on the side..
The pipe is simple up the wall and out.. braced with a 1 1/2 x 2 1/2 small stud.. (to be painted later)
I also put panel up above the backsplash and near the door..
and also over by the WFCO 'power center'..
Al
2016 WellsCargo FT6121 6x12
ywhic
Postby ywhic » Wed Dec 16, 2015 9:36 pm
Window should be here by Friday with hope.. Going to test install in 1" thick green foam board to make sure I get cut right before I start on side wall.. Lol
4000/3500w genny came in today via UPS. Only 1 day from Amzn.. Shipped from local DC I guess..
Al
ywhic
Postby AZ_Desert_Rat » Thu Dec 17, 2015 3:26 pm
Hi Al,
It looks like many of us had the same idea ... :lol: :lol:
Just added a second cam-lock and use the same lock to lock door latch open ... It keeps the jokers from locking the back door; I also added the RV side door... Doing great, keep up the good work :thumbsup:
Az Desert Rat's Backdoors
Rear View of Back Doors.jpg (30.8 KiB) Viewed 2607 times
Happy Camping & Building,
John (JC)
The Arizona Desert Rat 6x10' Cargo Conversion
The FunFinder a 19' Toy Hauler
An AZ Desert Transplant
Gallery: gallery/album.php?album_id=3168
AZ_Desert_Rat
Images: 55
Postby ywhic » Fri Dec 18, 2015 7:10 pm
So the 12"x24" window came in from vintek (teardroptrailerparts).. with a 1 13/16" trim ring.. I have 1 1/2" total wall width then the 3/16" thick paneling.
It has about 1/2" rubber gasket and flange all the way around..
I cut the trace 2x on cardboard that the window came in.. just to be sure..
Then I cut the hole.. I covered the jig saw with blue tape to keep chatter marks down.. Heres the window balanced in the bare metal..
The I slid the insulation back in.. to mark that.. and cut..
Then I marked the inner 3/8"' drymax by putting it in place with 3 screws..
Then I cut that..
I used some clear silicone on the rubber gasket to install..
Here is the inside flange/trim ring.. and the paneling up.. :thumbsup:
The only issue was the #8 x 1/2" ss screws.. they rounded out easy and I had to run out and grab replacements for them.. just stressful when all goes well with cutting and the the screws.. screw you..
Al
ywhic
Postby Rainier70 » Sat Dec 19, 2015 2:01 pm
Nice detailed window install. :thumbsup:
Rainier70
Images: 244
Postby ywhic » Sun Dec 20, 2015 6:17 pm
Thanks Ranier.. I try to do detail so others can read a step-step..
Today I cleaned the building materials debris from inside.. and recycled the luan trim strips for the top edges of the paneling..
I left about 1/4" near the top edges to slide in something for a ceiling..
The Mr Heater Buddy 4000/9000 btu took the trailer temperature from 38 to 70 the other night as a test.. I then turned it off..
I have the Mr Buddy 20# tank hose coming in for it.. It works great if you keep it near a vent and/or vent the window about an inch..
Don't mind the new 4000/3500w genny and spare.. 8)
Also installed the 'stab jacks'.. rated @ 1000 lbs each..
Still waiting on WireMold outlets and brackets for the rear outlets on the L/R.. Also waiting on the 'hose', and the CO2 sensor/alarm..
I need to get a carpet and padding in like 6x7.. I keep checking HD/Lowes for 'scraps.. and floor molding..
Alllllmost done..
Al
ywhic
Postby ywhic » Tue Dec 22, 2015 3:30 pm
Raining today (but like 55'f)..
Today I bought the better $55 'oak' accordion door from Lowes for the bathroom.
And some $20 carpet in 6x8 and $20 padding.. also got some trim molding for it..
Padding feels nice under there.. and will help insulate the 'living area' some.. Still need a trim strip..
Overall a decent small project day.. now to make lasagna.. :thumbsup:
Al
ywhic
Postby McDave » Wed Dec 23, 2015 2:57 pm
Amazing progress! :applause: You have something to be proud of there.
Merry Christmas.
McDave
McDave
Images: 412
Postby ywhic » Wed Dec 23, 2015 9:17 pm
McDave wrote:Amazing progress! :applause: You have something to be proud of there.
Merry Christmas.
McDave
Thanks.. next is the A/C trick.. ;)
Was going to do a slide type.. but don't want protrusion when it's slid inside the trailer..
I got some 1 1/2" AL coming in.. :twisted: and a 22x14 RV cargo door with lock.. stay tuned..
Al
ywhic
Postby lrrowe » Wed Dec 23, 2015 9:29 pm
Have you seen how MtnDon mounted his on the rear door?
Check his posts.
viewtopic.php?f=42&t=58336&start=195
Bob
lrrowe
Images: 439
Postby ywhic » Wed Dec 23, 2015 9:42 pm
lrrowe wrote:Have you seen how MtnDon mounted his on the rear door?
Check his posts.
Yuppers.. Thats where I got the idea.. but I am doing it inside the PINNED driver side rear door..
2x of the AL are 6' tall and then attached to the floor frame and the top of door framing..
2x of the AL will be horizontal to tie it together..
A/C will be removed for travel and will only be 40" +/- off the floor.. its the Fridg 5000K model..
The hatch is to cover the outside hole neatly..
I also have 2x of the AL to go horizontal on the outside of the door (just above and below the hatch, and it will be 'lagged' all the way thru the door to the inner horizontal AL framing..
Its basically going to frame out like a window inside with the AL and some 2x3 wood as well for addition support under the AL.. When the A/C is the hole, I just wingnut the edges into the framing..
I'm going to prefab the whole thing to get fitment correct.. then cut the hole for the hatch, then install the inner frame.
Al
ywhic
Postby lrrowe » Wed Dec 23, 2015 10:54 pm
I will be interested in seeing your photos.
Bob
lrrowe
Images: 439
Postby ywhic » Thu Dec 24, 2015 7:04 pm
Today the 'wiremold' items/parts came in via Fed Ex..
I used 2 of the 12ga (20 amp) circuits in the WFCO breaker box.. 1 on each side in the 'living area', each circuit is separate..
I have a total of 5 of the 20 amp circuits (all 12/2+g).. 1 for the counter top, 1 for the fridge, 1 for the water heater, and these 2 in the rear.
Also in the Buddy 10' propane hose adapter for 20# tanks.. and the 25' RV 30 amp cord to go to a plug at campground TT-30 or my generator (which has a TT-30).
Merry Christmas everyone.
Al
ywhic
Postby ywhic » Sun Dec 27, 2015 6:00 pm
Today I did the 'eye bolt' trick to secure the side door in the open position to avoid being locked in when I'm inside.
I also put down a carpet/floor strip and installed the CO2 monitor/alarm.
My sons over for a week.. so things are quiet..
Metal due in Tues/Wed and so is the 'cargo baggage door'.. going to see if my son will help on that project.. :?
Al
ywhic
Postby ywhic » Tue Dec 29, 2015 3:24 pm
My 14x22(x2") hatch came in today.. Inside opening is 12 1/2" x 20 1/4".. Seller had said 12" so I was stressing.. :o
Heres the 5K Fridg A/C slid in/thru it.. I have a 1/2" - 3/4" of height/wiggle room. Hatch was like $52 total with shipping and looks NEW..
I will be swapping the standard KEY lock for a barrel type lock..
The 2" flange on the hatch will get me thru the door and onto the AL channel (which also came in)..
Now to work with the AL inside frame..
Al
ywhic
