The Astroliner
Re: The Astroliner
Postby kayakdlk » Sat Jan 02, 2016 9:13 am
Great looking metal flake paint job :D :D :D :D :D
Dan
kayakdlk
Images: 392
Re: The Astroliner
Postby Atomic77 » Sat Jan 02, 2016 11:35 am
Thank you Dan! Looking forward to Flaking the exterior!
Michael
The Astroliner
Check out our YouTube video
Atomic77
Images: 309
Re: The Astroliner
Postby Atomic77 » Sat Jan 02, 2016 8:11 pm
Ok, so... Finished up the final details of the interior panels. They are all now ready to be installed. We are trying to figure out the best way to attach them to the wall. (Screws, glue, etc.) I need to come up with a way that doesn't mess up the paint. Suggestions welcome.
Each picture makes the panels look like they don't match but that's because of the viewing angle, lighting and such. The flake changes as you move...
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby Mushin » Sat Jan 02, 2016 9:12 pm
Beautiful work, great build!
Mushin
Re: The Astroliner
Postby Atomic77 » Sat Jan 02, 2016 9:14 pm
Thank you Mushin
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby roamer » Sat Jan 02, 2016 9:53 pm
VHB makes a clean install, albeit permanent.
[url][/url]https://www.youtube.com/watch?v=S_fM5cqSODc
Dave
If you think you can't, you won't
138765
roamer
Images: 25
Re: The Astroliner
Postby Atomic77 » Sat Jan 02, 2016 10:21 pm
The specs say it bonds metal, plastic and glass. I don't see anything about wood. Have you tried it? Permanent is fine... Once the cabinets and other walls are in they won't be going anywhere anyway.
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby KCStudly » Sat Jan 02, 2016 10:27 pm
How about that Hysol you mentioned? PLP maybe?
Is the back raw wood and what are you sticking it to?
Looks good, really good, absolutely effing fantabulous, BTW. :thumbsup:
Re: The Astroliner
Postby Atomic77 » Sat Jan 02, 2016 11:39 pm
Thank you KC... The back of the panel is raw wood. The walls they will be attached to are epoxied wood. Hysol would hold them in place... It's the extended cure time that I think would be the problem. Without a way to clamp them in place, it's a long time to wait.
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby aggie79 » Sun Jan 03, 2016 12:32 am
The interior panels - as does the rest of your build - are incredibly gorgeous.
As far as how to affix them, I would test PL Premium on some scraps. I bonded some non-epoxied would to epoxied wood in my build using PL Premium. I sanded the epoxied wood for mechanical grip, applied the PL Premium, and then clamped the pieces in place. I don't think that PL Premium expands like other polyurethane adhesives so strong clamping is not necessary. Maybe you could clamp around the openings and use some type of spreader bar/clamp around the perimeter (with of course some type of padding to protect the painted surfaces.)
Re: The Astroliner
Postby roamer » Sun Jan 03, 2016 11:23 am
Atomic77 wrote:The specs say it bonds metal, plastic and glass. I don't see anything about wood. Have you tried it? Permanent is fine... Once the cabinets and other walls are in they won't be going anywhere anyway.
Sorry didn't realize the back was raw wood.
There are a lot of adhesive products, just find one the cures quick or a way to hold the panels in place. Screws would take away from that amazing paint job! :thumbsup:
Dave
138765
roamer
Images: 25
Re: The Astroliner
Postby Atomic77 » Sun Jan 03, 2016 12:21 pm
That's what I'm thinking too! Glad you like it!
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby dales133 » Sun Jan 03, 2016 12:30 pm
Polyurethane adhesive will work.
You know im going to say sikaflex dont you :)
I on this build and the other one used a combination of vhb and sikaflex and its goung no where.
Use small sections of the tape to hold it while the glue gos off.
Love the pannels bro they are awsum
dales133
Re: The Astroliner
Postby Atomic77 » Sun Jan 03, 2016 2:43 pm
Thanks man... And yes I knew you would say sikaflex. It's just tough to get around here. 3M seems to have the market cornered. But as you and others have said, some type of polyurethane should work. It's just keeping it there while it sets up. That's why I'll probably try the VHB. I see there is VHB transfer tape as well as foam tape. Which exactly should I use? Also it doesn't say anything about bonding to wood. Any experience with that Dale?
Michael
The Astroliner
Atomic77
Images: 309
Re: The Astroliner
Postby les45 » Sun Jan 03, 2016 3:52 pm
How about one or two of these with some large pieces of padded 3/4 plywood to distribute the load:
https://www.etrailer.com/Truck-Bed-Acce ... 08908.html
I have an older one that uses screws on each end instead of the ratchet. I think I found it at Harbor Freight.
les45
Images: 605
