Ok here we go...PMF!
Re: Ok here we go...PMF!
Postby Sheddie » Sun Jan 03, 2016 12:37 am
Looking good mate. :applause:
What was the question you had about the doors?
Sheddie
Images: 1129
Postby dales133 » Sun Jan 03, 2016 12:40 am
Was seeing what you did to seal them.
And if you sealed around the outer perimiter.
I just stuck the putty tape stuff on the doors and screwed them up in the end,i was debating putting selant inside of the tape but i didnt.
Might use some selant from the frame to exterior skin though
dales133
Postby Sheddie » Sun Jan 03, 2016 12:48 am
I just used the putty tape stuff that came with them. By the time I screwed it all up the goo was oozing out nicely and it has all stayed sealed nicely.
Sheddie
Images: 1129
Postby dales133 » Sun Jan 03, 2016 1:37 am
Yea my goo oozed out 90%of the way around but some of it must be a bit further in from the edge and didnt.
It wont leak but it dosnt look 100% plus its grey so it clashes a bit against the green and the black
dales133
Postby Sheddie » Sun Jan 03, 2016 2:02 am
that is what it looks like close up, you don't really notice it at a normal glance, unless you have a really close look. Also it will probably darken after time.
Did you get the plstic strip to cover the screws? I don't think that Wayne in Kamo had it for his.
Sheddie
Images: 1129
Postby dales133 » Sun Jan 03, 2016 2:03 am
Yea i did but its the same stuff i got for my edge mold anyway
dales133
Postby dales133 » Sun Jan 03, 2016 2:04 am
I ended up cutting the door holes bigger on the inside and ive got a rubber t mould to fit there
dales133
Postby Sheddie » Sun Jan 03, 2016 2:25 am
I have thought about doing that too, with some sort of fender welt. Either the round edged one you see on VW guards, or piping on upholstery. One of those jobs that has not been on the priority list as it is not very noticeable.
Sheddie
Images: 1129
Postby dales133 » Sun Jan 03, 2016 2:27 am
I was going to use pinch weld but this little t mould is pretty discrette an slips in the gap and covers the door and wall by a few mms
dales133
Postby Sheddie » Sun Jan 03, 2016 2:32 am
What is the difference between the wall thickness and the door. On mine the door protrudes in about 3-4mm.
Sheddie
Images: 1129
Postby dales133 » Sun Jan 03, 2016 2:39 am
Mines almost flush.
They also have one the is like the same setup but with only one face leg that would suit you.
It tapers away to nothing so it fits well.
Hang on ill get a pic of these samples.
Para rubber should have them
dales133
Postby Sheddie » Sun Jan 03, 2016 2:45 am
Ta
Sheddie
Images: 1129
Postby dales133 » Sun Jan 03, 2016 2:47 am
dales133
Postby dales133 » Sun Jan 03, 2016 2:48 am
Its not that clear but the middle one has almost no leg on one side.
The other 2 are differnt t moulds
dales133
Postby Sheddie » Sun Jan 03, 2016 2:54 am
Thanks, I might have to look in to that. :thumbsup:
Sheddie
Images: 1129
