Ok here we go...PMF!
Re: Ok here we go...PMF!
Postby dales133 » Sun Jan 03, 2016 2:55 am
Clark rubber here is almost identical to para.
You may find somewhere cheaper though.
Im looking for hatch seals now too
dales133
Postby dales133 » Thu Jan 28, 2016 2:04 pm
Well for anyone that hasnt completly given up following my progress ive actualy made a fair bit but it was mostly grinding ,welding and flap sanding.
Im hoping by the end of today all the steel work will be finaly finished.
Had a good day yesterday and got all the front section and intermediate parts of the trailer complete and primed.
Ive put a topcoat on the whole thing in the dark so ill see how it looks this morning ,ill have to touch bits up later anyway but it needs to go back out in the weather so it was more for protection than anything else.
Ill post more pics today.
Heres a few from earlier yesterday.
dales133
Postby KCStudly » Thu Jan 28, 2016 6:39 pm
Looks good. Keep going! :thumbsup:
Postby Atomic77 » Sat Jan 30, 2016 12:04 am
Nice work
Michael
The Astroliner
Check out our YouTube video
Atomic77
Images: 309
Postby dales133 » Sat Jan 30, 2016 12:38 am
Pretty much done with the chasis except for the center mount for the deck plate / rod tube.
I ended up cutting out the top rear crossmember and replacing it with 25 x 25 as im now going to put a tailgate over the draws ect for a cleaner finish and better weatherproofing.
Only managed to get a couple of hours in today but im only a matter of hours away from fitting the water tank,plumbing and electrical along with the floor then the cabins back on for the last time.
I should be able to keep up some decent momentum now as long as the money tree keeps flowering.
Heres a pic of the tailight pods and the recess the tailgate shuts into.
Got a first coat of paint on everything i could the other night as its been super hot here and this paint hates hot weather.
A bit rough in places but 90% is covered anyway
dales133
Postby OP827 » Sat Jan 30, 2016 2:47 am
Looks good! :thumbsup:
OP827
Images: 414
Postby dales133 » Sat Jan 30, 2016 2:48 am
Thanks!
dales133
Postby Vedette » Sat Jan 30, 2016 12:00 pm
Looks Great Dale! :thumbsup:
Glad to see you back at it, I know it takes a while to get back in your groove after taking a break. :roll:
And I can feel your pain.....I spent 3 hours grinding the other night, and nobody even noticed the next day????? :cry:
Guess we just have to do the time!
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby dales133 » Sat Jan 30, 2016 5:16 pm
Thanks brian.
To be honest i had organised a few other people to do this for me as they would have been much faster and forseen some things i didnt.as it happens im realy happy with how it came out other than a couple of welds.
They have good penitration but are a bit ugly.
Ill grind them back and redo them or just linish them.
This all gets covered in checkerplate now anyway
dales133
Postby Sheddie » Sat Jan 30, 2016 7:12 pm
Hi Dale, it's really good to see you are back in to it. :thumbsup:
I think we all know what it is like with the areas that you seem to spend so much time on, then stand back and look at it :roll: and wonder what you have done all day :NC
dales133 wrote:I ended up cutting out the top rear crossmember and replacing it with 25 x 25 as im now going to put a tailgate over the draws ect for a cleaner finish and better weatherproofing.
Yes! I think that's a dam good idea. The back is an area where you can suck in a lot if dust etc. :thumbsup: Are you going to seal off that entire basement area :QM
Sheddie
Images: 1129
Postby dales133 » Sat Jan 30, 2016 7:17 pm
Yea.
As soon as all the weldings done witch isnt far off ill cut the aluminium for the floor and fit it.
Then the plumbing and draws,tow vechile wiring ect then the cabin gos back on and the sides are completly filled in except for 2 drop down doors either side at the front and a tailgate at the rear.
Still not 100%how im going to build the draws yet,timber or folded aluminium or a combination of both
dales133
Postby Sheddie » Sat Jan 30, 2016 7:53 pm
That slide system that Tony posted on here a while ago looked like it would work pretty well.
Sheddie
Images: 1129
Postby dales133 » Sat Jan 30, 2016 8:23 pm
Yea ive got all the bearings for it.
Just need to get the floor and draw frames in to work out sizes
dales133
Postby Sheddie » Wed Feb 03, 2016 12:25 am
Hi Dale,
FYI, if you are interested.
We had an email this morning from Anaconda in Australia. They have a sale on this weekend (finishes monday 8th). They have the "RV Shades" that we are using for side awnings on our teardrop at $118.99, down from $169.99.
Sheddie
Images: 1129
Postby dales133 » Wed Feb 03, 2016 1:02 am
Cool thanks for the heads up frank.
Off to the rugby 7s in sydney friday so gotta save my pennies!
Not to mention a few hundered dollars of aluminium and fabrication
dales133
