Pretty much done with the chasis except for the center mount for the deck plate / rod tube.
I ended up cutting out the top rear crossmember and replacing it with 25 x 25 as im now going to put a tailgate over the draws ect for a cleaner finish and better weatherproofing.
Only managed to get a couple of hours in today but im only a matter of hours away from fitting the water tank,plumbing and electrical along with the floor then the cabins back on for the last time.
I should be able to keep up some decent momentum now as long as the money tree keeps flowering.
- uploadfromtaptalk1454132218022.jpg (100.47 KiB) Viewed 1827 times
Heres a pic of the tailight pods and the recess the tailgate shuts into.
- uploadfromtaptalk1454132185516.jpg (112.67 KiB) Viewed 1827 times
- uploadfromtaptalk1454132110310.jpg (65.53 KiB) Viewed 1827 times
Got a first coat of paint on everything i could the other night as its been super hot here and this paint hates hot weather.
A bit rough in places but 90% is covered anyway
