I have searched the forum and can't find any products listed to seal the edge of my floor before installing the walls. It seems like most everyone goes the route of West Marine but I was thinking that surely there would be a readily available product that I wouldn't need to order that would achieve the same results.... Does anyone have any suggestions for something that I could find at a Lowes, Menards, Home Depot, etc?
I have a gallon of this two part epoxy that is used to seal/coat bar tops - could this be used? It is an epoxy resin and polyamine hardener. I wouldn't "flood" it on but would brush several coats until the wood quit absorbing. It wasn't cheap but I would use it if it would work.
https://jet.com/product/detail/f8ac6ca1edfe4ab497f58b072ebe3e94?jcmp=pla:ggl:hardware_a3:building_consumables_painting_consumables_varnishes_finishes_a3_other:na:na:na:na:na:2&code=PLA15&k_clickid=1519a31a-a075-473e-b32f-71a2b5cf4cae&abkId=403-183402&gclid=Cj0KEQiAisy1BRD7_YSgpduD2cEBEiQAPR3UuIIxwdIOcIhnDapzIpbJXbeQaVI1vcB_hwiQNmAZg7MaAq1y8P8HAQ
