Help I need a TINY interior light with switch (12v)
Postby SPLAT » Wed Feb 10, 2016 7:30 pm
The main dome lights are just a little out of reach when you are in bed so I thought I would install a couple small reading lights with easy access and mounted them at the front corners of the teardrop... The picture below is the light I bought and it is JUNK
Junk
I picked out a set that seemed small enough, however they were still kind of in the way. One never worked and the other one burned out after a few on and off cycles.
I have scoured the internet and found nothing that looks decent.
Does anyone know of a small 12v light with a switch that would would work well for this idea? Wish I could find a little surface mount light. :thinking:
Joe~
SPLAT
Images: 23
Re: Help I need a TINY interior light with switch (12v)
Postby Cosmo » Wed Feb 10, 2016 7:38 pm
Probably many other good alternatives.
I have a pair of lights very similar to this light. Mine only draws 150MA on high and 90MA on low.
This is not the exact light but it looks similar. I like mine very much. I did a search on Amavon for 12V LED wall lamp and a number of them popped up
http://www.amazon.com/Dream-Lighting-Br ... 9BB8VZ9D3M
Cosmo
FUN WITH TEARDROP TRAILER VIDEOS
https://www.youtube.com/CosmoWeems/videos
I am an Amazon Associate if you buy from my links I may profit at no cost to you!
Cosmo
Postby halfdome, Danny » Wed Feb 10, 2016 7:50 pm
I've been using these in my teardrops and they do a decent job of lighting.
Even though they have built in switches I install a built out 12 volt switch on the wall so we don't have to reach up to the ceiling to operate them.
I have to build switch boxes since my walls are only 7/8" thick and the connections for the switches protrude out the rear.
They have a swivel head so you can set them to where they'll illuminate the best for your needs.
My old supplier is no longer in business so if these interest you, their available here and more choices here.
They will accept LED bulbs if you like.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby SPLAT » Wed Feb 10, 2016 8:05 pm
halfdome, Danny wrote:I've been using these in my teardrops and they do a decent job of lighting.
:D Danny
So far that is at the top of my list! I can't believe how many searches I made and that fixture never came up!
Thanks :wine:
Joe~
SPLAT
Images: 23
Postby halfdome, Danny » Wed Feb 10, 2016 9:12 pm
I found them by searching for 12 volt aircraft reading lights.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Chello » Wed Feb 10, 2016 9:41 pm
These are the lights i'm planning on using as reading lights on the sides of the interior walls at the front of the cabin. I don't have them yet, but seem like they should work pretty well.
http://www.amazon.com/gp/product/B00MV1V80C?psc=1&redirect=true&ref_=ox_sc_sfl_title_7&smid=AIMGNG5XA4FRY
Chello
Postby dales133 » Wed Feb 10, 2016 10:25 pm
I have some realy good ones the same style i got from a company called hybralec.
They are here in australia but may be able to direct you to a supplier there or ship some over.
http://www.hybralec.com.au/store/produc ... ht-3w.html
The ones ive used are second from the lef ,top line.
3w led and throw out plenty of light
dales133
Postby noseoil » Wed Feb 10, 2016 11:13 pm
I got these from Amazon, same type of fixture. Not great quality, but they work. They're wired in place & were tested before I buttoned up the outside walls, just to be sure. I use a small AGM battery from an alarm panel & alligator clips for testing everything as I go.
137905
noseoil
Images: 670
Postby SPLAT » Thu Feb 11, 2016 1:42 am
noseoil wrote:I got these from Amazon, same type of fixture. Not great quality, but they work. They're wired in place & were tested before I buttoned up the outside walls, just to be sure. I use a small AGM battery from an alarm panel & alligator clips for testing everything as I go.
Different color, but those are exactly the lights I bought and they both were bad...
Thanks for posting! :thumbsup:
Joe~
SPLAT
Images: 23
Postby dales133 » Thu Feb 11, 2016 7:26 am
The bases on mine are similar but mine are full stainless and pretty decent quality.
dales133
Postby booyah » Thu Feb 11, 2016 8:48 am
These are what I used and couldnt be happier. Tons of light, very small, decent little lights. I use an external switch personally, but the little built in seems to work well as well
http://www.amazon.com/gp/product/B00AQKC7LO
Theres one light up off camera, and one turned off in pic
My build, 5x8 modified benroy "Smiles to go". Started April 2nd 2015, first trip August 2nd 2015.
viewtopic.php?f=50&t=63145
booyah
Postby bobhenry » Thu Feb 11, 2016 9:18 am
Mine came from Goodwill $.99 each less 30% for old farts day ($.69 each)
My lighting in Chubby is remotely switched so it is comfortable to reach the toggle switch while lying down.
The fireplace surround is now the headboard of the bed. The lantern is the interior light and the switch is about 15" below the light.
Postby vegask » Thu Feb 11, 2016 3:29 pm
vegask
Postby blentz » Thu Feb 11, 2016 5:41 pm
I have the lights that Chello is talking about. I hooked up one last night, I like it and ordered a couple more. I will have 4 of them in the cabin. 2 toward the cabinets With a switch at the doors and 2 at the head of the bed on the internal switchs.
blentz
Postby SPLAT » Thu Feb 11, 2016 7:30 pm
Thanks for the help everyone!
I decided to go with an aircraft style for now, it is flush mount so I don't need to modify the ceiling and it has a easy to find switch... :D :thumbsup:
Joe~
SPLAT
Images: 23
