Kev's First BC Benroy Build
Postby KEVBCBENROY » Mon Feb 15, 2016 10:42 pm
Thanks to all for the help and info on the many threads. I hope my build thread helps you with your next project...Cheers!
Day 1 - Rip apart a twenty year old Hitchman Utility Trailer...139418
Day 1 - Remove wheels, hubs, Strip it down and sand...139419
Day 1 - Prime and rust proof the frame...139420
Day 2 - Paint the frame...139421
Day 2 - Add new hubs, bearings and grease...139422
Day 2 - Install new wheels and 3/4"G1S 4x8 sheet of Fir Plywood for look and possible binding in tight corners...139423
Day 3 - Build extra 2x4 frame as this only a 4x6 trailer body...139424
Day 3 - Insulate floor, undercoat, Seal and paint...139425
Day 3 - Attach Floor with carriage bolts, nuts and washers and added angle brackets that came from HID ballast mounts in light fixtures from a jobsite. All hardware used was stainless steel with Robertson heads (Gotta love living in Canada!)...139426
Day 4 - Note Day reference is really just to help me load pics and not really what I accomplished that day. This total build took about three months of evenings and weekends but has been continued over last three years and revised many times. The white panel that you see is called FRP which was glued to the plywood for a really neat inside finish. Available at most hardware stores. This photo shows a jig with fulcrum and pencil to draw a smooth radius on the front and radius on the rear...139427
Day 4 - Rear plywood and FRP body contour. I used a jigsaw and fine tooth blade to cut the FRP carefully...139428
Day 5 - Locate and cut out door. I suggest buying doors pre-made as they are easy to source but I made mine from scratch (never again!)...139429
Day 5 - Glue FRP panels to Plywood and add heavy weight to dry overnight...139430
Day 5 - Same thing for the doors. glue FRP and Plywood together. I chose going with two doors for safety and am glad that I did as it makes it feel more open...139431
Day 5 - Cut all pieces with square edge and tools for accuracy...139432
Day 5 - Used many clamps to glue the FRP to the Plywood. I used FRP adhesive for this step and not contact cement...139433
Day 5 - Coat all exposed edges with undercoating and / or paint to ensure long life and waterproof seals...139434
Day 6 - Install temporary braces to hold the sides square and screw and glue together...139435139436
Day 6 - Install short front skirt...139437
Day 6 - Let all dry overnight...Starting to resemble something now...139438
Day 7 - Starting the trunk today. I chose 15" depth and will not be building the traditional trunk and hinge. Details to follow...139443139444139445
By the way, here is the radius PDF that I used for the body and doors...
Brian running the wedding sound at my daughter's wedding...
Done small IMG_0048.JPG (302.57 KiB) Viewed 216 times
Jumping ahead as it is now finished...
Done small IMG_4252.JPG (583.29 KiB) Viewed 216 times
Profile-Generic-Benroy.pdf
Profile for Benroy
(82.21 KiB) Downloaded 80 times
KEVBCBENROY
Images: 24
Re: Kev's First BC Benroy Build
Postby Vedette » Tue Feb 16, 2016 12:43 am
B.C. ??????????
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
