OverTheTopCargoTrailer wrote:I never figure this out with you all's 30 amp service.
20a x 120v = 2400 watts so how can this not be enough for a CT .... it's a lot cheaper than 30 amp wire.
Cheers ottct
Wolfscout wrote:
. . . On my new build I went with a 30 amp WFCO and 30 amp supply line from an Amazon seller. . . .
Thanks for your input, Larry
If you please, what is a WFCO?
My research showed me a company called WFCO that makes several products. You must be referring to one of their products. Which one, please?
Dave
walkrdg wrote:Just wondering... you said no brakes?
Wolfscout wrote: In my second build I'm currently working on... I put in a http://www.amazon.com/WFCO-WF8945PEC-WF ... 1_4&sr=8-4 (WF8945PEC) WF-8900 Series 45 Amp Power Center Converter Charger.
DaveMann wrote:Wolfscout wrote: In my second build I'm currently working on... I put in a http://www.amazon.com/WFCO-WF8945PEC-WF ... 1_4&sr=8-4 (WF8945PEC) WF-8900 Series 45 Amp Power Center Converter Charger.
I researched this piece. Let me see if I understand its purpose. Please correct me if I'm wrong.
AC power comes in from somewhere (let's say a 30 amp cable plugged into a socket on the outside of the trailer) and goes into the WFCO 8945. From there the power center does three things.
1. It provides a 30 amp main breaker and 5 AC circuits with individual breakers.
2. It provides 11 DC circuits (I'm not sure if this has fuses or breakers)
3. It provides a charging system for the battery.
Would you say that about covers it or is there more (or less) to it than that? Thanks again, Larry for your valuable input.
Dave
Gonefishin wrote: Be careful about using "parking lots" in the Keys. The Monroe County sheriffs and other enforcement people down there keep a close eye out for campers and trailers not in designated sites. I've seem 'em raise a big stink and write tickets even for an occupied RV in a private driveway or yard. Look forward to seeing how yours ends up.
m.colley wrote:DaveMann wrote:Wolfscout wrote: In my second build I'm currently working on... I put in a http://www.amazon.com/WFCO-WF8945PEC-WF ... 1_4&sr=8-4 (WF8945PEC) WF-8900 Series 45 Amp Power Center Converter Charger.
Dave
Hiya Dave,
Yes you have it right. It is a simplified way to include both 12V & 110V into your build. Your 12V will need ATC sized (auto size) fuses in the proper amp range.
Martin
