My Evil Plan
Re: My Evil Plan
Postby chiefairwrench » Sun Apr 17, 2016 7:10 am
Working hard on the electrics but planning on making my bed very soon. I want a queen size I know a short will work with my plan. I see 6" and 10" thickness which is better remember on a tight budget. They seen to be foam gel. :thinking:
chiefairwrench
Re: My Evil Plan
Postby Jrst67 » Sun Apr 17, 2016 7:57 am
following
Jrst67
Images: 7
Re: My Evil Plan
Postby McDave » Sun Apr 17, 2016 4:11 pm
chiefairwrench wrote:I purchased WFCO ULTRA III Power Center Model WF-8735Pa for my trailer since I am using more shore power than battery after getting my lights and started my wiring I realize that the negative is not available. Does my light negative runs back to the battery or to the frame? I am pretty sure I am missing something here. Install booklet was no help :frightened:
Hey Chief,
I just realized that I may have the answer to the ground/neg. (DC) issue. I have a WFCO 8955, when you have the faceplate off on the left hand side at the 9 0'clock is the ground terminal bar, AC ground (bare copper or green), DC neg, (black) and chassis ground go here. At the 12 'ish is the neutral bar (AC white wires). DC hots (red) to the fuses, AC hots (black) to breakers. Right hand side at the top is neg. (black) from battery, and RH side bottom is positive (red) from battery.
I believe your model should be similar. You can use chassis as ground for DC, but as you know most common failures in DC are ground issues, so cant hurt to have redundant grounds, black wire from DC light or pump to chassis and then to ground bar in the power center.
I believe your model should be similar. Hope I got this info to you in time to help.
Good Luck!
McDave
McDave
Images: 412
Re: My Evil Plan
Postby chiefairwrench » Sun Apr 17, 2016 4:26 pm
Great I wired my lights today except for 2 not much to show for 2 days of work but I get to start painting my walls since I dont have to open them again. :) Picture is on the way
chiefairwrench
Re: My Evil Plan
Postby m.colley » Sun Apr 17, 2016 7:15 pm
Looking good there Chief. I didn't get anything done this weekend on mine, ended up having to do brakes on the rear of my truck. My water pump made it here and my PD4045 should be here by mid week so then I can get started. You've got it looking good.
Martin
m.colley
Images: 83
Re: My Evil Plan
Postby McDave » Mon Apr 18, 2016 10:18 am
Hey Chief,
I was able to find some info on your WFCO 8735, not much, but enough to see it is a completely different animal from the WF 8955. I see that it comes with an attached pigtail for DC circuits ? Are they labled or is there a diagram inside the door or faceplate? The installation instructions that I was able to find are very vague, no wiring diagram or schematic. I apologize for misleading you on this, so as to the original issue they must intend for you to use chassis ground or a separate terminal block for DC neg. Seems odd that you would have to splice wires to circuits outside the converter box or maybe I am missing something. :?
Anyways, I hope I didn't lead you astray on this.
McDave
P.S. I did find this diagram, hope it helps http://i1271.photobucket.com/albums/jj6 ... gement.jpg
McDave
Images: 412
Re: My Evil Plan
Postby chiefairwrench » Mon Apr 18, 2016 11:24 am
Yes they are label and instructions on the door and back was better than the booklet
Sent from my SM-N910T using Tapatalk
chiefairwrench
Re: My Evil Plan
Postby chiefairwrench » Sun May 01, 2016 6:24 pm
Very good weekend dont look like much but almost got it back on schedule :)
chiefairwrench
Re: My Evil Plan
Postby chiefairwrench » Thu May 05, 2016 1:46 pm
Installed the rest of the plumbing, cabinet doors and tap :beer:
chiefairwrench
Re: My Evil Plan
Postby m.colley » Thu May 05, 2016 6:38 pm
Looking good there Chief. Keep up the good work.
m.colley
Images: 83
Re: My Evil Plan
Postby aggie79 » Fri May 06, 2016 8:36 am
m.colley wrote:Looking good there Chief. Keep up the good work.
+1 :thumbsup: :applause: :thumbsup:
Re: My Evil Plan
Postby chiefairwrench » Fri May 13, 2016 7:43 pm
Desperately needing help! I am trying to make my Murphy bed lower from the ceiling. I am using 90lbs garage door spring but they dont come down(expand) low enough cannot find longer springs. Is there an another method of rising and lowering the bed? :D :?
chiefairwrench
Re: My Evil Plan
Postby flboy » Fri May 13, 2016 8:48 pm
chiefairwrench wrote:Desperately needing help! I am trying to make my Murphy bed lower from the ceiling. I am using 90lbs garage door spring but they dont come down(expand) low enough cannot find longer springs. Is there an another method of rising and lowering the bed? :D :?
You could use 4 of these (gas struts) and have the bed lower onto a rail. I am designing a bed like this now for my toy hauler. I will try my hand at welding up a frame and building in rollers for the tracks. I have seen the same design only use 2 gas struts. I am assuming it has to do with the weight needed to be held up. Same principle however. Note there is only one track on each side in these pics. I have also seen them done with two. Before I set out to weld mine... I am going to take a trip over to a RV dealer and checkout some toy haulers, find some beds that use the gas struts.. then ask for a demo and take pictures. :)
http://www.ebay.com/itm/29-5-70-RV-Toy- ... Bl&vxp=mtr
4 Struts, build a frame that is guided by some track to rest on a ledge. Easy design. :thumbsup: :thumbsup:
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Re: My Evil Plan
Postby chiefairwrench » Sat May 14, 2016 12:37 am
That a great idea i think I may use come-alongs for right now only have one more weekend and suppose to be riding/camping in Florida. I already have my frame and tracks in place. :worship:
chiefairwrench
Re: My Evil Plan
Postby chiefairwrench » Sat May 14, 2016 12:46 am
if you see any of them take alot of pics that may work for me :thinking:
chiefairwrench
