5x8 Off-Road
5x8 Off-Road
Postby Fishingtomatoseed » Thu Apr 14, 2016 3:50 pm
Well here is the start of build number two. This one is for some friends that want to start camping and spending a lot of time outdoors. They finally pulled the trigger and so here we go!!
Design of trailer:
It is 5' wide 8' long 4' tall. The frame will be 2x2 tubing, 11ga and 3/16. The axle will be Flexiride with 30"x15" wheels. More pics coming soon...........
Fishingtomatoseed
Images: 9
Re: 5x8 Off-Road
Postby lfhoward » Thu Apr 14, 2016 4:18 pm
Looks like a good rugged design. I like it. What's the tow vehicle and what kind of lift/tires will you need to match?
lfhoward
Re: 5x8 Off-Road
Postby Fishingtomatoseed » Fri Apr 15, 2016 6:20 am
The tow vehicle at this moment is an F150. They are looking in the future to get a Chevrolet truck or Jeep. But they wanted the trailer to be "trail ready". More than likely we will tone down the size of tires for the trailer and match with hitch height for now.
Here is some frame pics:
Just laying it out:
Getting it squared up:
Working on the tongue angles:
Fishingtomatoseed
Images: 9
Re: 5x8 Off-Road
Postby Fishingtomatoseed » Mon Apr 18, 2016 6:48 am
Just welding the front up. Going to try and get the drive line mocked up this week and maybe have a rolling chassis this weekend?
Fishingtomatoseed
Images: 9
Re: 5x8 Off-Road
Postby Fishingtomatoseed » Sat Apr 23, 2016 6:21 am
Here are the drawings that I came up with for this trailer. If anyone would like to use them as a starting point go for it. I am using them now so there could be bugs in the drawings so use at your discretion and modify as needed. :D Let me know if anybody sees something completely wrong.
tnttt upload.pdf
Drawings
(42.98 KiB) Downloaded 409 times
Fishingtomatoseed
Images: 9
Re: 5x8 Off-Road
Postby S. Heisley » Sat Apr 23, 2016 8:17 pm
:thumbsup: I like it already.
Re: 5x8 Off-Road
Postby Fishingtomatoseed » Sun Apr 24, 2016 6:52 pm
S. Heisley wrote::thumbsup: I like it already.
Thank you.
Here are a few photos from this weekend. Installed the flexiride half axles. Got the bumper made and on. Recessed the lights and added a receiver hitch. Installed the front leveling jacks. Getting closer to paint!!!
Fishingtomatoseed
Images: 9
Re: 5x8 Off-Road
Postby Fishingtomatoseed » Mon Apr 25, 2016 12:57 pm
The time-lapse from this weekend.
Fishingtomatoseed
Images: 9
Re: 5x8 Off-Road
Postby Fishingtomatoseed » Sat May 07, 2016 1:02 pm
Went and picked up all the plywood yesterday at Central Hardwoods. All plywood is birch in 5x5 and 4x8. Seems like good plywood and I was able to get what I wanted with prices comparable to the big box stores. The core of the walls will be 3/4" with cutouts for insulation and laminated with 1/8" birch on each side. Planing on 1.5"x1.5" roof spars with the same 1/8" birch top and bottom. The chassis is coming along but not painted yet. Here is another timelapse:
Fishingtomatoseed
Images: 9
Re: 5x8 Off-Road
Postby aggie79 » Sat May 07, 2016 9:06 pm
Very nice!
Re: 5x8 Off-Road
Postby Fishingtomatoseed » Fri May 13, 2016 12:24 pm
Nothing exciting......Just laying out the walls to cut out.
Fishingtomatoseed
Images: 9
Re: 5x8 Off-Road
Postby dales133 » Fri May 13, 2016 4:43 pm
Nice build ill be following along
dales133
5x8 Off-Road
Postby Fishingtomatoseed » Wed May 18, 2016 8:52 pm
dales133 wrote:Nice build ill be following along
Thank you.
This past weekend we got the frame all finished up and got it primed. Also was able to cut out the wall structure. Not real happy with the quality of wood from Central Hardwoods. One of the 3/4" birch sheets had large section of unglued ply. Most of it was cut out and the rest I pulled apart and glued again.
So with my first build I discovered PL Premium and believe in it. So this go around I am using it again. We have glued one side of the 1/8" plywood to the framing. And then filling in the voids with blue foam.
I have never glued foam to wood before. So I am experimenting with the PL. I rough sanded the foam with 60 grit.
Then spread the PL with a notched trowel. Image
Wet the wood and using a weight to compress it over night. Tomorrow we will se how it bonds.
Fishingtomatoseed
Images: 9
Re: 5x8 Off-Road
Postby KCStudly » Thu May 19, 2016 11:08 am
Use caution when doing small scale tests with foam. You may get a false positive because a lot of the surface being glued is relatively close to an edge and has access to air, be it for ambient moisture cure or evaporation cure. This will not be the case on a larger panel glue up.
On some of the larger panels of foam where I laminated two pieces together using PL300, like on my hatch, I solved this problem by cutting shallow kerfs to act as air channels, or chimneys, in the foam.
Gluing foam to wood you can probably get away with a little spritz of water, or just wiping the wood with a slightly damp towel, in order to provide enough moisture for the cure.
I'm interested to see your test result. :thumbsup:
Re: 5x8 Off-Road
Postby Fishingtomatoseed » Thu May 19, 2016 8:43 pm
KC thank you for the information.
The results for the test pice was good. After 24 hours it was setup through out the pice. Granted my test was only about an 8"-10" triangle. I couldn't tear the foam from the wood with my hands. I had to take a putty knife and cut through the foam it self. Doing that and getting a corner up then pry with my hands. The foam would break where the knife stopped.
Before coming home today I stopped at the big orange store and picked up some more PL. Knowing that I was going to spread the glue out I looked at the 28oz tubes. For just a few more dollars you can get these. I just cut the tops off and used a 2x2 and pushed it out onto the ply.
Spreading the glue was a breeze with the v-notched trowel.
Laid the frame down and filled the holes with the roughed up foam. Walked around on it and added weights to hold every thing down. Before putting the foam in the holes I spritz water on those areas. So I hope that it cures KC. We will see........ I wonder with the ply only being 1/8" would it allow things to past between for the PL to cure?
Fishingtomatoseed
Images: 9
