Cooler if you have a half-galley
Postby justageorgiaguy » Fri Jun 10, 2016 10:34 am
If your teardrop has a half-galley (where the door starts at the counter top and not the bottom of the trailer), where do you have your cooler? Did anyone build one into the counter top? I've been debating on my design between having a full door with a pull out cooler, or trying to figure out what to do if I did a half galley. I know I can just store it in the jeep and put it on the ground, I'm just fishing for other ideas. :)
James Davidson
Photographer
http://www.jdavidsonphoto.com
justageorgiaguy
Re: Cooler if you have a half-galley
Postby KennethW » Fri Jun 10, 2016 10:42 am
If there is room just set it on the counter. Then use one of them low cost arm-less camp chairs as a stand to set it on when cooking.
125954clik to enlarge
KennethW
Images: 82
Postby PKCSPT » Fri Jun 10, 2016 12:48 pm
I have a small one that sits on the shelf. I am only out 1 or 2 days usually so don't need much. I have it set on its side like a mini fridge that uses ice.
You can see it to the right, the little white spot.
141240
121172 116946 159644
PKCSPT
Images: 61
Postby GuitarPhotog » Fri Jun 10, 2016 12:53 pm
My teardrop galley is full height, but has no room for a cooler, so I carry both (one for food and one for beverages) in the pickup truck and put them on side table next to the trailer galley when I set up.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby les45 » Fri Jun 10, 2016 2:45 pm
My galley countertop is in two pieces that slide over each other with storage beneath. That's where I keep the coolers, propane stove, coffee pot, and other camping gear. After I take the coolers out, they stay outside or store in the TV at night.
View of galley while still under construction.
View of completed galley.
les45
Images: 605
Postby justageorgiaguy » Fri Jun 10, 2016 3:23 pm
Thanks for the replies so far, I'm enjoying seeing the variations!
James Davidson
Photographer
justageorgiaguy
Postby drhill » Fri Jun 10, 2016 3:43 pm
There is lots of variations on how to do it for sure. Teardrops are all personal preference and the Galley is where most variation occurs. We have chartered several sailboats over the years and the cooler is commonly built into the counter top with a removable panel to get at the contents. It is effective and efficient in some ways, but at the same time very inconvenient to have to clear the counter to get into the cooler.
I used to camp in a full size GMC van and had tons of space but loading and unloading the camp stove, cooler, food box etc. drove me nuts. The teardrop kitchen can be so much easier to use. But counter space is at an absolute premium so plan carefully. I would (did) go with a fully hatch and a slide out cooler. But as I said - it is all about what you want to design and build.
Cheers,
Don
142406
drhill
Images: 37
Postby daveesl77 » Fri Jun 10, 2016 6:15 pm
Our galley is a bit strange and definitely unconventional. It rides under our bed frame. It takes less than 5 minutes to pull out and fully setup, including all water and propane hookups. About the same amount of time to put away. It sits under a shelter or has the ability to have a quick cover put over it. It gives us 11 linear feet of countertop and 13 cu ft of storage. The door access is water tight, so we don't have to worry about the potential of a hatch leak. It rides on roller bearings mounted on aluminum rails. The supports are aluminum tripod legs from an old tripod I had. The hot water heater rides in the compartment on the street side and attaches to the back of the stove side cabinet. It is essentially 2 boy scout camp kitchens with flip overs and hinged together. There is a thin plywood piece that slides in behind the cabinets when pulled out and seals the compartment. The door is fully sealed and angles down so water can't get into the camper. We have a fridge inside and also carry a cooler.
136570
136569
136567
136566
136565
136564
136563
136562
136561
dave
daveesl77
Images: 273
Postby Vedette » Fri Jun 10, 2016 9:13 pm
GuitarPhotog wrote:My teardrop galley is full height, but has no room for a cooler, so I carry both (one for food and one for beverages) in the pickup truck and put them on side table next to the trailer galley when I set up.
<Chas>
:beer:
Bring less Beer! :roll:
Where are you? :thinking:
We are in the midst of building the new deck........so jut think of how high we can get the flames going in that Barbeque?????? :twisted:
Hope you are having a great tome.
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Postby pete49 » Sat Jun 11, 2016 9:09 am
Rather than play with ice or its derivatives I use a Waeco 42litre fridge carried in the back of the wagon and setup on a stand near the galley while camped. Plugged in to the onboard battery with the solar panel out and working. Pays that there are no bears here :lol:
Just do whatever you want its your build and you're going to be the one using it. :thumbsup:
Pete
pete49
Postby wildcatphotography » Sun Jun 12, 2016 3:12 pm
wildcatphotography
Users browsing this forum: Google [Bot] and 1 guest
