by Cathy P. » Sat Jul 23, 2016 9:12 am
We are in Emporia, KS. And, yes, there are sheets, one that is the template: wheel well cut-out, sidewall pattern - use for building forward portion of sidewalls, front wardrobe wall & ice box wall, a long thin pattern piece for a word I can't read that well, something CA (maybe symbols) roof beam. There are 3 layout sheets that show construction and shows you what size pieces to cut out of each sheet of plywood. A listing of wood needed, by size piece, and always thought if I took up the street and asked the lumber company to custom cut it, it would like a kit, fairly easy, maybe. I have always thought the plans looked simple enough, I don't build things but do crafts and sewing.
