I considered the concept of a hole in either the CT walls but did not want to cut any more holes in it right now.
In general, I agree with you that sliding the unit in and out might be a good approach, but I also do not want to lose the counter, etc space.
I will have to leave one barn door party open for air circulation as shown below.
The AC sits nicely in a previously prepared shelf area. The aluminum pan is a temporary condensation catch basin until I can figure out a drain system. The next three challenges will be to figure out if I need to add circulation fans in the opening for better cooling air flow, how to secure the door for security reasons and how to keep rain from coming in. I have ideas for all issues.[/quote]
It looks like you have a rain drip edge above your door. So do I. I purchased some aluminum channel from Home Depot and made an awning. It has a woodend dowl in the free end with square stock on the ends. It fits into pins mounted ont he trailer wall. It installs in minutes and works well. i hold it on with spring clips
- DSC00187.jpg (211.7 KiB) Viewed 2644 times
Conform and be dull.
