First camper build
First camper build (lots of pics)
Postby jnelson » Thu Aug 18, 2016 4:06 pm
Last window installed and partially built cabinet
thermostat and fire alarm installed
led light and switches finished up, one switch is for the outside light. The light is kinda bright, might end up changing it .
interior dimensions are roughly 5' w x 8' L x 4' H
jnelson
Images: 6
Re: First tiny camper
Postby greygoos » Thu Aug 18, 2016 4:46 pm
Nice job. If i missed it my apologies in advance. Can you tell me where the battery is ?
greygoos
Postby jnelson » Thu Aug 18, 2016 5:12 pm
The battery as well as the inverter is in an action packer tote on the tongue, you can see it in one of the pictures.
jnelson
Images: 6
Postby jnelson » Thu Aug 18, 2016 8:29 pm
laminate flooring installed and cabinet doors on, still need to figure out some cabinet stays to hold the doors open.
jnelson
Images: 6
Postby jnelson » Thu Aug 18, 2016 8:34 pm
fabbed up a mount for a little 19 inch LED tv, used a weld on hinge so I can just lift it off during transport
jnelson
Images: 6
Postby jnelson » Thu Aug 18, 2016 8:48 pm
first test tow around the block, need to get a hitch with more drop to level it out otherwise it towed really nice
jnelson
Images: 6
Postby jnelson » Thu Aug 18, 2016 8:49 pm
my ol beast of a truck
jnelson
Images: 6
Postby dogscats » Thu Aug 18, 2016 11:22 pm
Very nice like the back.
TODAY IS THE OLDEST YOU'VE EVER BEEN,
YET AT THE SAME TIME, THE YOUNGEST YOU'LL EVER BE,,, SO MAKE THE BEST OF IT WHILE YOU CAN, AND ENJOY THIS DAY WHILE IT LASTS
dogscats
Images: 20
Postby jnelson » Fri Aug 19, 2016 8:49 am
so back to the furnace, i didn't want to mount it inside the camper as it would take up too much space and the fan noise would be annoying in such a small space. Here is a picture of the initial test, it was around -5°c and it kept it nice and toasty. I attempted to sleep in it that night but i ran out of propane around 3 am.
The test was successful so i needed a box to mount the furnace in, i found a small tool box that was the perfect size.
modified slightly, the propane line and power/thermostat cables go through the front of the box
i wanted to keep it portable so i could bring it only when needed. Excited for winter camping now! :D
jnelson
Images: 6
Re: First camper build (lots of pics)
Postby jnelson » Fri Aug 19, 2016 9:32 am
jnelson
Images: 6
Postby jnelson » Tue Feb 14, 2017 1:58 pm
Hey guys just a quick update. After using the camper a few times with the furnace here are my findings. We took it out in the fall time with lows around 32°F and the furnace worked great, cycled on and off as it should with the thermostat and we were quite comfortable. Took the camper out again in late November when the temps were colder and had a couple issues that i need to address. When the furnace comes on it has a pre-purge which blows for about a minute before the air is hot, this causes the interior temp to drop quite quickly as the space is so small. The same scenario happens when the furnace shuts off, cold air is blown in causing the thermostat to have a call for heat before the furnace turns off.. I think these problems stem from the furnace being mounted externally and ducted into the front of the camper not the traditional way with the furnace inside the camper. Maybe i need to make an insulated box for the furnace and have insulated ducts :thinking:. What are your guys thoughts??
jnelson
Images: 6
Postby Socal Tom » Thu Feb 16, 2017 3:40 pm
I think insulated ducts would help, I'm not sure about a whole insulated box. You could also look at dinosaur boards and see if they have a board that might reduce the blowing.
Sent from my Lenovo A7600-F using Tapatalk
Socal Tom
Postby Shadow Catcher » Thu Feb 16, 2017 8:14 pm
You could also set up the ducts to use with an AC unit http://tnttt.com/viewtopic.php?f=30&t=44561
Great build!
Postby jnelson » Mon Mar 18, 2019 9:08 am
Just a couple update pictures. We've really enjoyed using the camper the lastest couple years. Here's a few pictures of adventures with the camper as well as some of the upgrades. The awnings and awning room are great and provide a large living space.
Sent from my SM-G965W using Tapatalk
jnelson
Images: 6
Postby Az Pete » Mon Mar 18, 2019 4:55 pm
Very nice!
Couple of questions:
did you figure out a solution for the heater blowing cold air during start up and shut down?
do you get any dust infiltration or build up on the flat back of your camper?
Az Pete
