McDave wrote:Hey Don,
You wouldn't happen to have an example of the relay for the back-up lights? Just tap into TV reverse light wiring and use that to trigger relay in trailer and house battery, correct?
Thanks,
McDave
McDave wrote:What is your parts source? I'm using the same LED ramp lights as you and Martin. If I remember correctly 18 wt each, so it only need to be 5-10 amp ? Should be able to find one at Napa etc.? Relay in parallel with house switch, OK?
Are you wired for TV to house battery charging? If so, tap into keyed circuit, then 30a fuse on hot to 7 pin, Then 7 pin to 30a to house battery? Or use relay here as well? So keyed circuit to trigger, hot from TV battery to relay, to 30afuse to 7 pin, 7 pin to house battery?
Oh yea, speaking of old age.... celebrated 22nd year of wedded bliss Thurs. Sept1, and the 27th anniversary of my 29th birthday on Wed. Sept. 7... Yep, 29 ain't what it used to be...Ya know?![]()
McDave
