toypusher wrote:A fracking earthquake?Actually saw that on the news. Never heard of it before.
Yeah, the USGS calls them "induced earthquakes."
CD
caseydog wrote:A two leg zoom is moving your two legs to get closer or farther from the subject with a prime (fixed length) lens.![]()
I still use a 70-200 zoom lens for distance stuff, because with long lenses, I am often limited in my ability to back up by fixed obstacles. For closer work, I'll use a 24mm prime or 50mm prime, and do my "zooming" with my legs.
CD
caseydog wrote:I'm glad I could make your day a little funnier, sir sheepman.
Now, what exactly qualifies as "warm humid" air in Maine? At this moment, in the middle of the night, it is 88 degrees, and 82-percent humidity at the doghouse. I mowed the lawn just before sunset, so it was probably warmer then. I took a much needed shower, and gave my dog a bath after the yard work was done.
We do have a "cold" front about two hours away, and moving fast. The high temperatures are expected to be in the 80s after it passes, and drier -- maybe 30-40 percent humidity.
I can only assume that heat and humidity weren't an issue on your alien sheep planet.![]()
CD
Fenlason wrote:Our weather people use dew points.. not percent of humidity. This recent.. I was talking relative.. comparing to where we should be, and to what we just had. We have had morning temps down in the 40's.. and a couple of days of highs in the 60's.. Our average frost date is Sept.15th. The past couple of mornings it was humid enough that you pick up water droplets from the air walking in it, and started with temps in the upper 60's. We did reach the upper 80's and low 90's
caseydog wrote:Fenlason wrote:Our weather people use dew points.. not percent of humidity. This recent.. I was talking relative.. comparing to where we should be, and to what we just had. We have had morning temps down in the 40's.. and a couple of days of highs in the 60's.. Our average frost date is Sept.15th. The past couple of mornings it was humid enough that you pick up water droplets from the air walking in it, and started with temps in the upper 60's. We did reach the upper 80's and low 90's
I've never taken the time to get a grasp on the dew point thing. I do know that when I work in places like Houston and New Orleans, and go from inside air-conditioned spaces to outdoors, I have to wait until my lenses de-fog to take any pictures.![]()
What you describe is like camping in winter down here. It gets cold at night, and you breath inside your tent or teardrop, causing moisture to condense on the inside walls -- that sometimes drip on you. Very annoying.
CD
