7'*18' V-Nose Cargo Trailer Toy Hauler Conversion
Postby McDave » Sat Oct 15, 2016 7:04 am
Maybe just hang that one underneath? Along side of tank/poop shoot?
You could still cut another hole in the side, just for fun. If you can find a spot!.... :lol:
McDave
McDave
Images: 412
Postby McDave » Sat Oct 15, 2016 7:10 am
flboy wrote:Hi McDave. I really don't like the finish work so much, but have to get it done.
I actually have one just like that from the donor camper. There is nowhere inside for it to go, except up front on the V.. I think I am going to mount something underneath the trailer. I may go with a variation to the 5in square PVC fence post, with the gutter tray to pull out.
Sent from my SM-N900P using Tapatalk
I'm leaning that way, myself....http://www.livinlite-owners.com/thread/ ... easy-steps
McDave
McDave
Images: 412
Postby flboy » Sat Oct 15, 2016 7:27 am
McDave wrote:Maybe just hang that one underneath? Along side of tank/poop shoot?
McDave
That made me laugh. Thanks! :lol: :lol:
Maybe I will cut a hole just for fun. :lol: :lol: :lol:
The square fence post will mount easier than rounded PVC and I like the idea of the gutter that I can pull out to lay the hose in. Thanks for that link. I hadn't even thought of the square PVC Fence post prior to that.. :thumbsup: :thumbsup: :thumbsup:
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby McDave » Sat Oct 15, 2016 7:38 am
Hey Don,
Here's a little upgrade idea. Could be handy...
https://www.amazon.com/iGlow-Outdoor-Ga ... ost+lights
McDave
McDave
Images: 412
Postby flboy » Sat Oct 15, 2016 7:45 pm
Hi McDave.. those lights are nice... all my 12VDC lighting is effectively solar with 500W of cells on the roof and 345aH of battery capacity on board.
Finally... back to work on the trailer after dealing with Hurricane Matthew last weekend. This is what I got today. I put the face on the electrical closet and finished the doors for it.
I'll mount them tomorrow and install the hardware. I ran out of time today (took the wife out for dinner and a stroll on the beach... major brownie points for me). It is a beautiful full moon here tonight and the sea looks angry (huge surf)...
Tomorrow and next week it is on to more trim work and final plumbing.
Don (Flboy)
flboy
Images: 378
Postby flboy » Sun Oct 16, 2016 3:09 pm
Got the doors mounted and put on the hardware. Looks good to me, but now I have to figure a good way to build the latches. Long story.. but it is not cut and dry as you'd think.
I have a vent louver to put on the bottom panel which is not a door. I have one for the top side by the entrance door. Convection should keep air circulation in the electrical part of the cabinet up top. The long door will be a closet to hang clothes once I conceal the wiring. I just need to panel inside the closet to conceal the wires.
Don (Flboy)
flboy
Images: 378
Postby McDave » Mon Oct 17, 2016 4:13 am
Hey Don,
Those cabinets are SOOOooo Nice! Really sharp and clean, simple and elegant. That looks much nicer than what you see in manufactured campers. I really like it, but I'm not showing it to my wife. I don't want to have to start this whole project over!
Nice Job!
McDave
McDave
Images: 412
Postby McDave » Mon Oct 17, 2016 4:21 am
Seems like I remember seeing cabinet handles similar to yours with a push button that moves a spring loaded latch. I suppose there is a strike mounted to the cabinet face.
McDave
McDave
Images: 412
Postby flboy » Mon Oct 17, 2016 5:24 am
Thanks McDave. It is starting to come together. I'll take some pics later of why I am having trouble with latches. It has to do with the way the door frames line up with the cabinet faces... too much overlap. I have an I idea and I think I may use the magnetic catches.. and epoxy the plate on the inside of the door panel.
My sister is off sewing up my dinette cushion covers. I can't wait to get those back. I need to start finishing off the dinette soon.
Don (Flboy)
flboy
Images: 378
Postby McDave » Mon Oct 17, 2016 11:16 am
I have the spring loaded rollers on the face with strike on door set up. The rollers pinch onto the strike when closed.
They are nice when you are parked, but DO NOT trust them in transit. Everytime I opened the door after transit, sh*t was everywhere and the doors were beatin' the hell out of themselves. I ended up drilling a 1/4" hole through the frame and into the edge of the door so I could "bolt"/pin them together. The pins are hidden pretty well and are on a piece of chain and hung/screwed right near the hole so they don't get away when parked. Same basic set up for the reefer. The pin just sets in front of door and blocks it from opening. Part of the issue is these are all real solid wood doors, they are over 125 years old and they're heavy. Also I didn't have stuff secured well enough with nets and bars. I'm learnin' though.. after I lost about $70.00 worth of some kickass Brisket between Sturgis and Belle Fourche. Stopped to gas up and opened the door, everything was out of the fridge, and it looked like Custer's Last Stand in there. Meat and sauce and buns and slaw and beer from floor to ceiling, and all over the Harley. Now, I'm not sayin' it all went to waste. But the wife didn't get any.
The Jameson was not damaged, so no biggie. Had to hose her out anyways after Sturgis. The trailer, not the wife. You know what I mean.
But I digress, and ramble...
McDave out.
McDave
Images: 412
Postby flboy » Mon Oct 17, 2016 7:57 pm
Hi McDave, the problem is mounting the latches... not necessarily the type. The width of the cabinet faces is the same as the door framed. The mating side of the mounts would have to be screwed into the door panels which would look odd and are only 1/8 in thick. This was an oversight on my part. This is the first time I ever built cabinets, so I "live and learn".
I think I have the problem solved in any case. I bought some 88lb (pull force) round real earth magnets that I can embed in the face to make them flush and then screw the steel plate onto the door frame . Should work perfect given the door frames are offset from the cabinet faced by the thickness of the panel (1/8"). The door will shut flush and those magnets are so much stronger than your door magnets at Home Depot that I saw, which I'd also have an issue mounting.
If the two magnets work well... I'll repeat for the remainder of the doors.
I will be getting the baby lock straps for the fridge. Those worked well for my last build. Sorry to hear about the mess you had.. I learned that the hard way also...
Don (Flboy)
flboy
Images: 378
Postby McDave » Mon Oct 17, 2016 11:58 pm
Ah yes, Rare Earth. One of my all time favourites. They really work hard. Been a while. Check this out..
https://www.youtube.com/watch?v=o3Z8NU5ImK0
McDave
McDave
Images: 412
Postby flboy » Tue Oct 18, 2016 5:23 am
McDave wrote:Ah yes, Rare Earth. One of my all time favourites. They really work hard. Been a while. Check this out..
McDave
Brings back some old memories... you can find some good stuff on Youtube!
Don (Flboy)
flboy
Images: 378
Postby Tommy B » Tue Oct 18, 2016 1:04 pm
Hey Don thought of you when I saws this. Hope they are not your friends.
The bodies of two experienced divers were pulled Monday from a deadly underwater cave system in Florida known as the "Mount Everest" for diving enthusiasts
Man be careful if your still going on that dive trip. If you need an adrenalin fix just hang on for some single track!
Tommy B
Postby hankaye » Tue Oct 18, 2016 7:35 pm
flboy, Howdy;
I gotta say, for someone that likes to play in the dirt (sand), and water an all white
interior is not what I'd have gone with ... You my friend are truly a brave individual.
Either that or you are kin to Felix Unger ... :thinking:
Whichever it is it sure looks clean , neat and did I mention WHITE.
hank
hankaye
