vttrampers wrote:I am starting a 5x8 Benroy build and was planning to use the Northern Tool Ultra-Tow aluminum trailer as the platform. I just saw, however, that the "features and benefits" list includes a 45 mph max. towing speed restriction. The trailer seems to be essentially identical to the widely used Ironton steel model, so I'm not sure what to make of the speed restriction. The 1,715-lb. payload capacity and 1980-lb. max. GVWR are essentially the same as the steel version and the axle/bearings/wheels seem similar. Is this one of those lawyer-induced lawsuit protection deals or there really some reason to question the utility of the trailer? The weight savings is a real draw, but not if there is truly an issue with the Ultra-Tow version.
Does anyone out there have experience/insight with this trailer?
Thanks!
hospadar wrote:Hey!
I'm using the same trailer (the aluminum one) as the base for my project. I used the stock tires to haul some supplies from Sturgeon Bay, WI to Ann Arbor, MI (round trip, about 1k miles). Drove 55 the whole way, no problems, but the trailer was un-loaded.
From what I could find to read about the Norther Tool trailer and bias-ply trailer tires in general is that the main risk is blowout due to overheating (which happens more easily in trailer tires because of the thick sidewalls) when you have the wrong combination of load/hot temperatures/long-hauls. The impression I get is that most/all road-rated (not agricultural) trailer tires are fine up to 55 in normal conditions, and probably fine going faster so long as you're not hauling an overloaded trailer in circles around death valley.
All that being said, just to give myself some peace of mind, I replaced the stock (bias ply) tires with radials. Unless you get a wider axle that will accomodate 13 inch tires, these are pretty much your only choice for the northern tool trailer: http://recstuff.com/trailer-tires-wheel ... d-range-e/
The radials are rated for higher speeds (65, same as all other trailer tires) and are generally just better than bias ply tires (less heat, higher speed ratings)
Ordered from recstuff, I got three tires (left/right & a spare), mounted on galvanized rims & shipped for <$150.
I'm planning on a super-long road trip that's going to involve a lot of long-hauling through hot places next summer which was the main reason I was particularly concerned - I think if I was just planning on cruising around in-state I'd just set the cruise control to 55 and not worry about it. $150 bucks to reduce the risk of a really awful blowout on the highway seemed worth it to me.
.Spacers are a bad idea. They change the load on the bearings and studs of the axle. Think longer lever now. Wheels with less back spacing would be a better route
