Spare tire
Spare tire
Postby Kaz » Sun Jan 15, 2017 7:25 pm
Where did you mount your spare tire, one of the thing's I overlooked in the build process.132994
Kaz
Kaz
Images: 122
Re: Spare tire
Postby dancam » Sun Jan 15, 2017 7:50 pm
I havent yet, but am planning to mount it under the trailer close to the axle.
dancam
Re: Spare tire
Postby friz » Sun Jan 15, 2017 8:29 pm
dancam wrote:I havent yet, but am planning to mount it under the trailer close to the axle.
My plan too. My battery is going down there also.
Sent from my Altair 8800 using Tapatalk
The "Sin Bin"
150133
friz
Images: 6
Re: Spare tire
Postby Ron Dickey » Sun Jan 15, 2017 11:43 pm
I am playing with that too, on my new build. on my old trailer I carried it inside the front bonnet. On trailer wait should be more to the front or needed to counter your galley in the back.
One man build a cage under the frame and put a lock on the side so if he needed it, it was out of the way and yet handy without climbing under it. many by the HF tire mound and put it on the tung. I have seen it mounted on the front wall of flatter front trailers. Yet other keep it in the unit that pulls it. Still other use the same size tire that they use on the puller and just carry one spare.
You might want to look at google images location of trailer spare tire, or location of teardrop trailer spare tire
One could even make a dropped floor, under the bed to hold it.
my other idea was to make it a table at the front, on my first trailer I was going to make it into a rear table but it did not work for me.
here is that discussion 2009 viewtopic.php?f=35&t=30874
So, on my new trailer I wanted it to be on the front but that means no front bonnet but this man made it better. viewtopic.php?f=21&t=58565
now I really have your head swirling.
:? Ron
173882......173887
Ron Dickey
Images: 787
Re: Spare tire
Postby les45 » Mon Jan 16, 2017 6:25 am
I have not mounted my spare tire on either of my builds. I simply carry it along with my trailer tool kit (spare hub, wrenches, etc.) in the back of my TV when traveling. I keep it stored in my garage mainly to keep it from deteriorating from outside storage. I also keep my two trailer tires coated with Armorall and covered when not in use. I've found that tires deteriorate more from exposure to the elements during storage than they do from actual use.
les45
Images: 605
Re: Spare tire
Postby drhill » Mon Jan 16, 2017 10:07 am
That is a nice looking teardrop Kaz
I went with the under trailer storage. In over 40 years of towing many trailers I have only needed a spare once. I got a compact spare from the wreckers with the 5 x 4.5" pattern I needed and supported it under the trailer with an old broken bike frame. A piece of angle iron would work just fie too. I had it in front of the axle (as in this picture) but moved it to behind the axle to free up the space under the doors for shoe bins that slide in under the trailer at night. The compact spare doesn't need to be the same size as your regular tires as it won't matter if the trailer is exactly level if/when you ever have to use it. I used a few chain links at one end for the "hinge" end of the carrier and a turnbuckle at the other end. I put a cable tie through the turnbuckle to prevent is vibrating open.
125109
drhill
Images: 37
Re: Spare tire
Postby dguff » Mon Jan 16, 2017 11:39 am
les45 wrote:I have not mounted my spare tire on either of my builds. I simply carry it along with my trailer tool kit (spare hub, wrenches, etc.) in the back of my TV when traveling. I keep it stored in my garage mainly to keep it from deteriorating from outside storage. I also keep my two trailer tires coated with Armorall and covered when not in use. I've found that tires deteriorate more from exposure to the elements during storage than they do from actual use.
Ditto!
Jerome
2008 Guffman
dguff
Images: 69
Re: Spare tire
Postby working on it » Mon Jan 16, 2017 2:50 pm
When first contemplating a location, I saw that I couldn't mount my spare under the trailer, for lack of clearance (I thought I would off-road it, later), so I mounted mine directly to the front wall (an advantage for a flat, non-teardrop front end),
  • 97624 original mounting
I have a single beam drawbar, and having the open space on top of it, I thought it ideal to let the spare tires' weight be supported by it. I used a 1/2 diameter carriage bolt to secure it to my front wall, with a self-centering bearing inside the hub. I used locking chains to make it safer. But, after I reluctantly, HAD to have a tonguebox (for balance/storage needs), I really couldn't find another place for the spare; besides, by then, I liked the look, and then again, the weight balance would change. I didn't favor the appearance of the 27" diameter tire conflicting with the width of the box, and after I found a box of similar width (to the tire),
aluminum tonguebox.jpg (22.7 KiB) Viewed 2323 times
I devised a sliding tonguebox mount,
  • 113816 made a triangular base from treated wood
  • 114027 attached boat-seat sliders to it
  • 114187 added upside-down caster to support alum.box plate (red circled)
  • 114188114350 mounting plate pull handle, locking latch (for travelling)
  • 114351 flexible connections to battery in box
  • 114373 spare tire neatly tucked behind tonguebox!
and kept the spare in its' original space (just unlock the base, slide the box forward, access the spare). A lot of work to make, sorta complicated, but it works.
tonguebox with spare tire secured.jpg (75.22 KiB) Viewed 2323 times
Last edited by working on it on Tue Jan 17, 2017 9:02 am, edited 2 times in total.
173193172890148599
working on it
Images: 457
Re: Spare tire
Postby cshane » Mon Jan 16, 2017 9:44 pm
added mine on the front vertical for show, but decided to angle it a little so I could put the battery access behind it.
Sent from my SM-G930V using Tapatalk
cshane
Re: Spare tire
Postby Shadow Catcher » Mon Jan 16, 2017 10:25 pm
We do not have one. I bought an adapter so that I can use the TV spare.
9289592896
Re: Spare tire
Postby RonS » Mon Jan 23, 2017 10:58 am
Having worked at a garage that also did towing and roadside assistance, don't mount the spare under the vehicle. If/when you need it and you're out and it's rainy/snowy/muddy etc you'll thank me. Also remember, your trailer isn't going to be as high off the ground with a flat tire, and you should NEVER be under a vehicle supported by a jack.
Why do we drive on a parkway and park on a driveway?
RonS
Re: Spare tire
Postby lrrowe » Mon Jan 23, 2017 12:24 pm
While not for a TD, I am designing a swing away system for my barn door CT which will mount on the back and swing around to the side. For me, this will allow for better weight distribution and easy access for my rear galley.
Bob
lrrowe
Images: 439
Re: Spare tire
Postby bbrider » Thu Feb 02, 2017 12:45 pm
Mine is mounted on the tongue and pivots from flat to vertical when I need in my box.
2017-01-30 13.16.04.jpg (466.96 KiB) Viewed 2074 times
2017-01-30 17.26.06.jpg (358.75 KiB) Viewed 2074 times
Naw Bro, We ain't lost. We just ain't never been here before!
Wee-Go build journal:
viewtopic.php?f=50&t=66964
bbrider
Images: 42
Re: Spare tire
Postby GuitarPhotog » Thu Feb 02, 2017 1:21 pm
I didn't build my teardrop, it was made in 1948 with no provision for a spare. So I built a bulkhead forward of the door to hold the electrical panel, battery, and spare tire. So, it's in the cabin with me. Along with the jack, lug wrench, and axle stand.
<Chas>
:beer:
GuitarPhotog
Images: 55
Re: Spare tire
Postby swoody126 » Fri Feb 03, 2017 8:05 am
RonS wrote:Having worked at a garage that also did towing and roadside assistance, don't mount the spare under the vehicle. If/when you need it and you're out and it's rainy/snowy/muddy etc you'll thank me. Also remember, your trailer isn't going to be as high off the ground with a flat tire, and you should NEVER be under a vehicle supported by a jack.
EXCELLENT ADVICE :thumbsup:
sw
swoody126
