Things are moving along, and the ACM is working great.
![Image](http://uploads.tapatalk-cdn.com/20161202/968153b36c8b65f43b29b5cdb3d863e6.jpg)
Cut the basic wall out of 3/4 plywood
![Image](http://uploads.tapatalk-cdn.com/20161202/7f61f5321100232def9f7dcbfefa0b44.jpg)
Roughed up the backside of the ACM with some 150 grit sandpaper to help the adhesive have something to grab onto
![Image](http://uploads.tapatalk-cdn.com/20161202/944e0c916d46e1861dd3f4d030123fcb.jpg)
Loctite Premium PL adhesive
![Image](http://uploads.tapatalk-cdn.com/20161202/13a8e2941661b867d16fadc3fe7e5041.jpg)
Laid the glued up wall down on the ACM, walked all over the backside to spread out the adhesive, and "clamped" with a bunch of cinder blocks
Let dry for 24 hours
![Image](http://uploads.tapatalk-cdn.com/20161202/be17fb35e399580c26b94caa7a5c8dd6.jpg)
After it dried, flipped the wall over onto the worktable to trim the edges. Moved it outside because cutting ACM can get messy.
![Image](http://uploads.tapatalk-cdn.com/20161202/a78018b6c2ade13c4fb5c6a6fb6acf86.jpg)
Flush trim bit on the router
![Image](http://uploads.tapatalk-cdn.com/20161202/23ee011a13e12ffabaabc49bb6abf2c7.jpg)
Router cuts extremely well thru the ACM. Thought I might need to pretrim closer to the final shape, but no need.
![Image](http://uploads.tapatalk-cdn.com/20161202/3c69761b988ec48a9f757d73aa95b553.jpg)
And there is the final wall mounted to the floor.
Sent from my XT1080 using Tapatalk
