1st build
Re: 1st build
Postby kathy chorjel » Tue Apr 11, 2017 12:53 pm
Thanks for the heads up jwh, gonna check into that!
kathy chorjel
Images: 35
Re: 1st build
Postby pchast » Tue Apr 11, 2017 8:13 pm
With a little care and a triangular file those saws can be satisfactorily sharpened.
pchast
Images: 97
Re: 1st build
Postby kathy chorjel » Wed Apr 26, 2017 7:11 am
So, I finally got up the nerve to cut the hole for the a/c vent. Not nearly as difficult as my head made it out to be, just nerve racking... gotta insulate where the e track is to see how it works in the heat of the day, but inside was 72 degrees in the early evening last night.
148063148064148065148066148067148068
kathy chorjel
Images: 35
Re: 1st build
Postby ffemtp » Thu Apr 27, 2017 8:07 am
[quote="kathy chorjel"]So, I finally got up the nerve to cut the hole for the a/c vent. Not nearly as difficult as my head made it out to be, just nerve racking... gotta insulate where the e track is to see how it works in the heat of the day, but inside was 72 degrees in the early evening last night.
I am going with the exact same setup in my CTC. I was wondering if there was a reason you didn't choose to vent through the floor. I have a 6" round duct that I plan on installing to run the exhaust under the trailer. This would eliminate any issue for leaks and needing a "perfect" hole in the skin.
Also, let me ask a couple of questions. I saw where FLBOY had used this setup previously but decided not to use it any more because the high current drain on startup. My point is that he had previously set it up so that the intake was vented to the exterior as well. Do you think that will be an issue? If so, how do you plan on effectively dealing with it. Secondly, as I consider venting through the wall, did you use a 6" louver? if so, where did you get it? Is the louver on the outside of the deck plate mount? I can't exactly tell what you did there. Thanks!
ffemtp
Re: 1st build
Postby kathy chorjel » Thu Apr 27, 2017 10:03 am
@ffemt. Went with the side vent because there was already a 3" vent in place. I put the marine hatch on the inside and a 6 " dryer vent on the outside. (copied off Coventry kid) got them both on amazon. The louvered vent covered any imperfections in the cut and they lined up almost perfectly! Having to shim a little with duct tape and foam , and put some paracord attached to the hose through the vent to keep it in place as I didn't use the window attachment for the unit.
kathy chorjel
Images: 35
Re: 1st build
Postby McDave » Thu Apr 27, 2017 10:22 am
:applause: :applause: :applause: :thumbsup:
There ya' go. Nice clean work, well thought out, planned and executed. I think you may have a future in this business.
See? It's not so tough. Kinda reminds me of an old Cat Stevens song. You know the one? Rod Stewart made a fortune off it.
Everybody sing...
https://www.youtube.com/watch?v=c5NRH_DxWJE
McDave
McDave
Images: 412
Re: 1st build
Postby kathy chorjel » Thu Apr 27, 2017 7:38 pm
LOL, good one McDave!
kathy chorjel
Images: 35
Re: 1st build
Postby hankaye » Fri Apr 28, 2017 8:24 am
McDave, Howdy;
It's all your fault! Next time I go to contemplate where to install a window I'll be hearing
that earworm over and over and over again :( , very :( .
hank
hankaye
Re: 1st build
Postby CoventryKid » Sat Apr 29, 2017 2:31 pm
Kathy:
We're on the road right now - in Brookings, OR - enjoying some much appreciated warmth and sunshine.
My louvred vent "flaps" at speed on the highway. In fact one of the 4 vanes got stuck underneath the one above it - I initially thought I'd lost a vane.
I drilled a couple of small holes in the top and bottom of the cover and clipped on a really small bungee cord. This has cured the "flapping".
Hope this doesn't happen to you but if it does....
Doug
Vancouver Island, BC
GMC Savana Explorer Limited SE hightop conversion van
NEO NAVR 7x16 V-nose aluminum trailer now a comfortable travel trailer
Build: http://www.tusker-international.com/1-trlr-build.html
CoventryKid
Images: 130
Re: 1st build
Postby kathy chorjel » Sat Apr 29, 2017 7:17 pm
Thanks for the heads up Doug! Sounds like a good fix for it too.
Well, I ran the ac in the near 90 temps we had today. Only got to 78 inside... :( I haven't yet insulated the walls,(I know, I know...) but I just had to see. I did cover the obvious areas that would pull in warm air, just wondering if there is anything else to try before I start tearing it apart... :thinking: I really want to start building cabinets and stuff!
Also figured out that the manual vent the factory installed is kind of a cheap piece of crap.
kathy chorjel
Images: 35
Re: 1st build
Postby kathy chorjel » Thu May 11, 2017 1:30 pm
148242148241148240
Current situation. Started taking the trim off to insulate. I can't get the ply off without removing the box for the ramp spring. These star screws are a pita to remove and are half stripped coming from the factory putting them in. The one that is causing the current dilemma is in the exterior skin and I don't want to ruin the integrity of the skin. Any suggestions?
Also, it sure is hot out today... think I'll go for a ride.
kathy chorjel
Images: 35
Re: 1st build
Postby kathy chorjel » Thu May 11, 2017 6:50 pm
picked this up tonight on my little ride. gonna try it out tomorrow. "Speedout"
kathy chorjel
Images: 35
Re: 1st build
Postby Rainier70 » Thu May 11, 2017 7:47 pm
If your star driver isn't fitting right then the "star" screws are probably double squares. If so use a #2 square bit driver to take them out.
Rainier70
Images: 244
Re: 1st build
Postby kathy chorjel » Thu May 11, 2017 9:29 pm
Rainier70 wrote:If your star driver isn't fitting right then the "star" screws are probably double squares. If so use a #2 square bit driver to take them out.
Hmmmm.
kathy chorjel
Images: 35
Re: 1st build
Postby onehoser » Fri May 12, 2017 5:59 am
the screws holding the interior panels in my trailer are 8 point torx too, the red robinson screw driver works perfectly
I am the wisest man alive, for i know one thing, and that is that i know nothing. (socrates)
onehoser
