Off-road Teardrop Design/Build
Re: Off-road Teardrop Design/Build
Postby kokomoto » Thu Mar 02, 2017 7:04 am
The toys for the TV Cherokee have arrived.
TV upgrades
kokomoto
Postby kokomoto » Tue Mar 07, 2017 2:48 pm
I finally got around to the walls. I'm glad that I bought the biscuit joiner. After the top arch glue joints dry, I'll add the vertical pieces and bottom board.
Wall 1
Wall 2
The other wall
kokomoto
Postby kokomoto » Tue Mar 21, 2017 3:48 pm
Finally finished the skeletons. Now getting all of the pieces together to glue them up with 1/4" plywood.
Skeleton 1
Skeleton 2
kokomoto
Postby kokomoto » Tue Mar 28, 2017 12:52 pm
After gluing the skeleton to the inner wall plywood, I cut the 1 5/8" ledge for the spars. I stopped the cut at the forward edge of the upper bulkhead.
Before cutting the rear part of the wall for the galley lid notch, I wanted to confirm that it is 2".
Wall 1
Wall 2
Wall 3
kokomoto
Postby kokomoto » Thu Mar 30, 2017 5:26 pm
More wall progress. Hope to have the walls completed, and attached to the floor this weekend.
Wall 1
Wall 2
Wall 3
kokomoto
Postby kokomoto » Sat Apr 01, 2017 8:54 pm
More progress on the walls. I didn't follow the process in Steve's manual to the letter, and now I am finding out why I should have. :oops:
Also build the dead man for holding the walls in place while I attach them to the floor. I should have something that will start to resemble a teardrop camper soon 8)
Wall 1
Wall 2
Wall 3
kokomoto
Postby kokomoto » Mon Apr 03, 2017 7:42 pm
I decided to use pure tung oil on the interior plywood. I've been using RAKA epoxy on the floor, and still intend to use it on all of the external plywood. I think it will protect the wood very well. I haven't mastered applying it with smooth results though. It's on there, but not beautiful. I applied the tung oil per the instructions. It went on really easy with no fuss, and looks great so far with 4 coats. I plan to add two more coats. I bought a quart, and that looks like it will be enough to for the entire interior of the cabin and galley. I was too busy to take pics, but I'll post some pics soon.
kokomoto
Postby kokomoto » Tue Apr 11, 2017 9:14 am
More goodies for the TD.
I bought two of these lighting fixtures. One for the cabin and one for the galley.The two lights can be turned on separately. I plan to replace one of the two with a red led bulb so that we can use red lights when needed instead of the white.
lighting fixture
s-l400 (1).jpg (15.41 KiB) Viewed 2916 times
Here are the door locks/latches with deadbolt. Keyed alike.
latches
kokomoto
The walls are up!
Postby kokomoto » Fri Apr 14, 2017 9:11 pm
Lots of progress this week. The walls are up as of tonight. PL premium drying while the Kreg screws hold it them in place.
Just waiting on a delivery of 5x5 1/8" birch for the ceiling so that's on hold. Time to start on the doors, and maybe the hatch frame in the meantime.
Floor installed
Port wall up
Port profile
kokomoto
Postby kokomoto » Fri Apr 14, 2017 9:19 pm
The Mrs is starting to think this is kind of a big deal now. :thumbsup:
Kokomotogirl helping
2 walls
Finally
kokomoto
Postby kokomoto » Tue Apr 25, 2017 9:35 pm
I have installed the door jambs fabricated from1/2" birch ply.
I decided to cut a window in the back wall. Not sure if it's a good idea or not, but I like it for some reason. First ceiling panel is also installed. I'm starting to get to the point where a lot of things have to be done in order. Have to be careful.
Still dreading the hatch and door construction.
First ceiling panel
Rear bulkhead window
Also picked up a new cooler and water jug to keep in the galley.
Galley so far
kokomoto
Postby aggie79 » Wed Apr 26, 2017 2:57 pm
Very cool! :applause: :thumbsup: :applause:
Postby kokomoto » Wed Apr 26, 2017 3:51 pm
aggie79 wrote:Very cool! :applause: :thumbsup: :applause:
Thanks Tom! :beer: It"s starting to get interesting.
kokomoto
Postby kokomoto » Sat May 06, 2017 4:56 pm
The roof is now half completed.
Roof foam
Outer skin
kokomoto
Postby kokomoto » Sat May 06, 2017 5:00 pm
Installed dual LED light fixture in the cabin.
Cabin ceiling
Also cut the hole in the ceiling for the Fantastic fan.
Fan hole
kokomoto
Users browsing this forum: coal_burner and 9 guests
