Canvas Tarp Suppliers
Postby Ned B » Fri Jun 09, 2017 8:10 am
I was thinking of a retro vibe with two tone matching my car and an off white, unless I can get the teal canvas and the glue doesn't discolor it.
If I'm going to paint it, I'll just get plain and put a similar color over it.
Ned B
Re: Canvas Tarp Suppliers
Postby greygoos » Fri Jun 09, 2017 7:55 pm
I havent tried it but I was wondering if you used a colored canvas and painted over it with untinted paint base. i know that untinted paint was used on one of Woodbutchers builds instead of I believe varnish or epoxy.
greygoos
Postby GPW » Sat Jun 10, 2017 5:26 am
Might be good to test that , as the color might fade in the Sunlight… There are UV coatings you can use ...
Postby ghcoe » Sat Sep 01, 2018 11:23 am
Thought I would post this up.
My last purchase of a 12x9 canvas drop cloth at Harbor Freight did not have a seam through the middle. Not sure if it is a fluke of not, but if this is the new standard for HF canvas then it could be a good thing. Cost was the same and quality seemed the same.
George.
George.
ghcoe
Postby tomhawk » Sat Sep 01, 2018 1:20 pm
FWIW, I bought two 12x9 canvas tarps from HF at separate times during the last 6 months. Neither had seams.
Evolution is driven by mistakes, not plans.
My build: https://www.tnttt.com/viewtopic.php?f=55&t=75248
tomhawk
Images: 104
Postby ghcoe » Sat Sep 01, 2018 1:25 pm
That is great! :thumbsup: That means now you should be able to do 11'x8' spans. :thinking:
George.
ghcoe
Postby GPW » Sat Sep 01, 2018 1:42 pm
I’m guessing they don’t like you to open them up to check for seams eh ? :oops:
Postby ghcoe » Sat Sep 01, 2018 11:15 pm
GPW wrote:I’m guessing they don’t like you to open them up to check for seams eh ? :oops:
Probably not. Hope they will all be that way soon though... :thumbsup:
George.
ghcoe
Postby GPW » Sun Sep 02, 2018 5:25 am
Guys, we just found a huge source of really Heavy Duty Burlap Coffee bean bags… So Heavy and Tough a fabric we use them to make Archery targets ( stuffed to the max with recycled plastic bags ) … The local coffee company gives them away for free… 8)
Postby Tyrtill » Mon Apr 08, 2019 6:42 pm
Just got back from harbor freight and mine doesn’t have seams either and for you guys with harbor freights til the end of the month Image
Tyrtill
Images: 14
Postby ghcoe » Mon Apr 08, 2019 6:59 pm
Good to hear. Thanks for the update! :thumbsup:
George.
ghcoe
Postby Tyrtill » Sat Jun 22, 2019 7:06 am
Apparently they change suppliers I bought some in different packaging.
This is the packaging for the seamless one
This is the packaging for the inferior seamed one. There are more snags as well as a center seam (running the long way)
Tyrtill
Images: 14
Postby RJ Howell » Sat Aug 31, 2019 1:23 pm
Thank you for that! My local one only had the seamed one.. Now I know what to look for!
RJ Howell
Images: 36
Postby RJ Howell » Sun Sep 01, 2019 3:07 pm
Tyrtill wrote:Apparently they change suppliers I bought some in different packaging.
Thank you again! I went to a different HF store today and grabbed the seamless canvas! The salesperson told me that all stores carry both types and that my local store must have sold out.
RJ Howell
Images: 36
Re:
Postby kronan » Sat Jan 21, 2023 2:42 pm
GPW wrote:The covering material Must be porous to allow the solvent in the glue (water) to evaporate/dry ... As long as the material "breathes" , no matter its composition , it will attach to the foam with a T2 type adhesive ... Canvas, fiberglass, Kevlar , Carbon fiber... all will work ... Plastic , metal, pasta, will Not work ...unless a more suitable adhesive is used...
Hey GPW - I’m just brand new in here. Been trying to learn PMF.
Not ready for a camper yet - but just a few projects to get the feel for it.
So - question re: fabric. I wondered if Fiberglass will work well ( or Kevlar) with Titebond II.
I have a Composites guy nearby - and I’m sure he would slice me off a few yards at his cost.
So I have a smaller project to start with - Tonneau cover for pickup. PMF over XPS
(or, I do have some EPS on hand, but not sure if that will work out ok ??)
So perhaps I just need 80 Sq. Ft ( 40 top, 40 bottom.)
My goal is Light / Thin / Strong.
So I don’t mind spending a few extra bucks on, say, glass vs canvas… if it would be lighter weight.
But I would love to confirm that it will glue up nicely.
Then I would paint; or try MonstaLiner or equiv, as per the big write-up by Tony L (?)
Just looking for direction here.
You seem knowledgeable on this - perhaps you can give me some input. Really appreciate. Thanks.
kronan
