If I'm going to paint it, I'll just get plain and put a similar color over it.
GPW wrote:I’m guessing they don’t like you to open them up to check for seams eh ?
Tyrtill wrote:Apparently they change suppliers I bought some in different packaging.
This is the packaging for the seamless one
This is the packaging for the inferior seamed one. There are more snags as well as a center seam (running the long way)
GPW wrote:The covering material Must be porous to allow the solvent in the glue (water) to evaporate/dry ... As long as the material "breathes" , no matter its composition , it will attach to the foam with a T2 type adhesive ... Canvas, fiberglass, Kevlar , Carbon fiber... all will work ... Plastic , metal, pasta, will Not work ...unless a more suitable adhesive is used...
