fourbtgait wrote:3m VHB tape to attach the outer skin to the tubing instead of screws/rivets.
No insulation factor but will help cut down direct transfer.
fourbtgait wrote:I agree that insulating the inside of the tube does not negate thermal bridgeing. It simply helps to reduce it.
A 1/2" to 4" dead air space as shown on commonly accepted tables only provides an R1.
aggie79 wrote:A couple of items for thought:
1. I agree that "spray foaming" the square tubing will negligible if any impact on heating and cooling. There may however be the following possible benefits of insulating square tubing:
a. Displacing the air with closed cell insulation should reduce or eliminate condensation within the square tubes
b. If you outer trailer skin is attached by screws or rivets into the tubing, that are subject to loosening over time due to vibration and flexing, the closed cell insulation should act as a seal to prevent moisture intrusion.
2. Continuous insulation works from a thermal standpoint, but:
a. The typical variability in insulation panel thicknesses will make it difficult to get a smooth plane for interior finish skins.
b. Attaching upper cabinets, if being used, will be a little more tricky. Because the insulation can compress, cabinets may requiring anchoring to a substrate (plywood) on behind the insulation - not the interior finish skin - or to the directly to the CTC's square tubing.
OverTheTopCargoTrailer wrote:I gotta say ten stars for the man named tylerjd. where were you when OTTCT was born ? You really payed attention in school.....
I'm cooling to 72F with solar and mini split in 7 x18 CarMate wood frame trailer using under 300 watts per hour parked in full sun 100F or Texas 90F with 85% humidity. 3" dow blue board 6" denim in the roof. no heat required until outside drops below 32F
cheers OTTCT
