Murphy Beds
Murphy Beds
Postby phoenixbound » Wed Oct 04, 2017 7:33 am
I am planning to put a Murphy bed in my CTC. I looked at some images of others and I really like this setup shown. Has anyone made a similar setup? Wondering about type of hinges, leg setup, mattress options, etc. I got this pic in a google search. It may be from someone in the group, if so NIce Job!!!
murphy bed1.jpg (38.67 KiB) Viewed 6973 times
murphy bed2.jpg (44.17 KiB) Viewed 6973 times
Smart enough to know that I still have a lot to learn.
Build diary at viewtopic.php?f=42&t=69652
phoenixbound
Re: Murphy Beds
Postby onehoser » Wed Oct 04, 2017 8:26 am
check out my build viewtopic.php?f=42&t=68016
if you need more info/pics, let me know
I am the wisest man alive, for i know one thing, and that is that i know nothing. (socrates)
onehoser
Re: Murphy Beds
Postby onehoser » Wed Oct 04, 2017 8:38 am
you can sort of see the type of hinges i used on the folding legs and i used 4 of the same hinges for each half of the bunk.
i used a 1x2 strap to keep the legs moving together so that they drop down evenly since they don't hang quite plumb because of the offset location of the hinges.
btw that was that exact same pic i used to design my bed, lol
hope this helps
onehoser
Re: Murphy Beds
Postby phoenixbound » Wed Oct 04, 2017 8:52 am
Thanks. I am guessing you didn't use piano hinges from what I can see. My secondary concern is "locking" the legs so they don't fold up while the bed is being used. I also wouldn't mind if one side could be dropped and use for seating. Thanks again.
phoenixbound
Re: Murphy Beds
Postby onehoser » Wed Oct 04, 2017 9:08 am
a better shot of the hinges
onehoser
Re: Murphy Beds
Postby Socal Tom » Wed Oct 04, 2017 10:00 am
Years ago I had a similar setup in a ford van. I spaced the first hinge further off the wall, so that the mattress pads could fit in the space when it was closed up. I used the same type of hinges seen in the photo. I never had a problem with the legs sliding out once the bed was down, but if that is a concern, a slide latch like this could be used to lock the legs in place.
Socal Tom
Re: Murphy Beds
Postby jwhite » Wed Oct 04, 2017 10:25 am
64427644236655377611
here is mine a regular piece of shelving pine was the right size
jwhite
Images: 46
Re: Murphy Beds
Postby phoenixbound » Wed Oct 04, 2017 10:49 am
Very helpful replies, thanks. I only have about 4" of clearance with my Harley Tri-Glide loaded to work with. So, it can't be wider than a 2 x 4 when is up against the wall. Probably use a air mattress for the bed.
phoenixbound
Re: Murphy Beds
Postby McDave » Wed Oct 04, 2017 4:04 pm
I just use one of the 22" high deluxe air beds. I sleep like a baby. Takes 2 min. to deploy or deflate with the built in pump. Folds up and stows about 1'x2'x10", weighs approx. 10lbs. Works for a couch (sort of) as well. I only sleep in it 20-30 times a year, but I like it, a lot. Full size fits tight crossways, (Head at one wall, feet at the other) and still leaves room to move around in the cabin 6'x12'. Best $45.00 I have spent in a while, problem solved, zero construction.
McDave
McDave
Images: 412
Re: Murphy Beds
Postby phoenixbound » Thu Oct 05, 2017 2:29 pm
phoenixbound wrote:Very helpful replies, thanks. I only have about 4" of clearance with my Harley Tri-Glide loaded to work with. So, it can't be wider than a 2 x 4 when is up against the wall. Probably use a air mattress for the bed.
Tri-Glide fits pretty good with about 7" on each side. Looks like the Murphy Bed will work nicely. Also got E-Tracks installed. Getting there.
14 loaded back 3.jpg (128.67 KiB) Viewed 6707 times
phoenixbound
Re: Murphy Beds
Postby Socal Tom » Thu Oct 05, 2017 3:00 pm
I would suggest 2 inches of memory foam over the air mattress. That would sleep really well and still leave you plenty of room.
Socal Tom
Re: Murphy Beds
Postby phoenixbound » Thu Oct 05, 2017 3:55 pm
Thanks Tom. I had considered that. Any idea what a queen size piece of 2" memory foam would cost? I would actually need 2 pieces equal to a queen size. Thanks again.
Mark
phoenixbound
Re: Murphy Beds
Postby Socal Tom » Thu Oct 05, 2017 4:43 pm
About $60 on Amazon
Socal Tom
Re: Murphy Beds
Postby McDave » Wed Oct 11, 2017 10:28 am
Lippert makes a lot of RV stuff. I don't know how to buy them, may have to go through a RV dealer. Here is a PDF for 2018, at the end of the catalog look for PT # 12626/000A/00/001 Smart Bench. May give you some ideas.
https://assets.lci1.com/lci-eu/2018-lci ... esized.pdf
McDave
McDave
Images: 412
Re: Murphy Beds
Postby phoenixbound » Thu Oct 12, 2017 8:00 am
Wow, nice stuff. I'll keep it in mind. Thanks.
phoenixbound
