6X12 SS&S
Re: 6X12 SS&S
Postby flboy » Sun Sep 24, 2017 12:42 pm
Great work on that manifold!! I'd expect nothing less from you. :thumbsup: :thumbsup:
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Re: 6X12 SS&S
Postby Iconfabul8 » Mon Sep 25, 2017 2:54 am
Thanks everyone for the kind words!
Hank, it's not the first time I have been associated with Rube Goldberg. Haha, Not sure it's a good thing, going about doing simple tasks in a complex way can get a net thrown over a guy if he isn't careful :?
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby Iconfabul8 » Thu Sep 28, 2017 2:35 am
The fresh water drain valve and tube are in and the pump is mounted and plumbed (not pictured.)
Also, I got the hot water manifold done and mounted. Just a little FYI,
The locations where the manifolds are mounted was determined
by where the stainless hoses from the shower mixer reached to.
A close up of the hot water manifold.
One connection to the water heater, another
to the shower and one to the sink.
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby Iconfabul8 » Fri Sep 29, 2017 3:27 am
One step closer! The pot is plumbed :applause:
Tomorrow, the pressure test :frightened:
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby flboy » Fri Sep 29, 2017 7:24 am
It is looking really good. I hope the pressure test goes well. My money is on no leaks.
Don (Flboy)
flboy
Images: 378
Re: 6X12 SS&S
Postby hankaye » Fri Sep 29, 2017 9:07 am
Iconfabul8, Howdy;
I see you're going the "Industrial Strength" path. Can't have to many shut-off valves,
:thinking: , think I've read that somewhere else on here ... :thinking: , but I agree.
:thumbsup: , :thumbsup: .
hank
hankaye
Re: 6X12 SS&S
Postby Iconfabul8 » Fri Oct 06, 2017 5:18 am
Finally getting around to building the DC panel. Made a discovery by accident
(was drilling the hole for a different switch,) If you drill a 1 1/2" hole with a
butterfly bit, you only have to chisel out a little from the corners to make
a single rv switch fit nicely in a piece of wood.
Nothing too special about a crimped on spade, except that It alowed me to put
a little meat on the wire so the connecter (very long ground bar that I cut into little pieces)
would bite on it.
Cut off the prongs
View of wire in connector.
Side view of finished board
Front View
Back view of early wiring stage. Missing the white wire from the shunt to the ground buss.
View when you walk in the door. Still need the countertop and tiny sink installed.
I believe I am going to leave the front open like this. All along I have been shooting for
the Captain Nemo/Starwars/SteamPunk type look.
Side view
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby McDave » Fri Oct 06, 2017 5:34 am
That's some nice Journyman like work right there. Just a pleasure to watch a pro do his thing.
McDave
McDave
Images: 412
Re: 6X12 SS&S
Postby hankaye » Fri Oct 06, 2017 8:15 am
Iconfabul8, Howdy;
When I first viewed your last post I was thinking this guy is bumpin' into
the steam-punk zone... Then I read the post and you confirmed it.
hank
hankaye
Re: 6X12 SS&S
Postby m.colley » Sat Oct 07, 2017 5:13 pm
Nice looking work there Icon, really nice..
Martin
m.colley
Images: 83
Re: 6X12 SS&S
Postby Iconfabul8 » Thu Oct 26, 2017 12:40 am
I've been chomping at the bit to get this little job done.
Built this little brass plate for my volt/amp meter
It's kinda nice to finally see what's going on in those wires.
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby jr9744 » Thu Oct 26, 2017 3:12 pm
Thanks for posting the pics of the plumbing. Looks really good!!
7x7x16 V Nose Travel Trailer, First Build...In Progress
http://www.tnttt.com/viewtopic.php?f=42&t=68569
jr9744
Images: 311
Re: 6X12 SS&S
Postby Iconfabul8 » Fri Oct 27, 2017 1:33 am
jr9744 wrote:Thanks for posting the pics of the plumbing. Looks really good!!
Thanks, yeah I am not a huge fan of behind the wall plumbing in a trailer. I have two pex connections under the bathroom floor and they even make me a little nervous.
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby Iconfabul8 » Wed Nov 29, 2017 11:20 pm
Finally got the last few pieces of insulation stuffed into the top corners.
YAY! more finish molding up. :D I was handed a pile of this molding when I picked up the trailer because
I ordered the trailer without the molding installed. Now I can custom fit it to my build just the way I want it.
Iconfabul8
Images: 14
Re: 6X12 SS&S
Postby McDave » Thu Nov 30, 2017 3:27 pm
Hmmmm... I didn't get any moulding with my trailer. That makes for a nice clean finish in a hard to deal with area. The radius corners everywhere don't work well with normal construction materials. I do like the high privacy windows.
Very stealthy from the outside. ... 8) ...
McDave
McDave
Images: 412
