Nope.
flboy wrote:Ramp or doors. Can always keep them closed. Something hard to put in later and think of resale. For me.. got to have ramp for dirtbike, 4 wheeler or Kingpin. Don't limit your future options and never say never. ;-) . I learned that lesson.
McDave wrote:That sounds like you got a pretty good education and some sage advice. I really can't comment as to the dual axle or extended tongue. I have no experience with those, however if you don't go with the v nose, regular tongue has room for LP, batteries etc. and should be ok as far as jacknife scenarios. I've never had a problem. I would highly recommend additional height, even 6" would make a big difference to average sized American males 6'0" 200lbs ish. Just that little extra would allow you feel like you can stand up straight. My head doesn't always hit but it feels like it will, so I slump down and it gets old fast. Also, your average home refrigerator would fit better standing up if moving, other furniture as well.
McDave wrote:As far as your electrical set up I would recommend 12vdc and 120vac 30 amp to begin with and then add solar as budget permits. The most common way to do this is a power center like the WFCO8955 or PD4045. It will give you AC circuits that are breaker protected, DC circuits that are fuse protected, battery charging and 120 to 12v converter. Most common stuff like lights and pumps and fans are 12v, and if you need to run something 120v while not on shore power you can use an inverter. Otherwise you can run 12v when on shore power and charge battery, and charge from tow vehicle and from a generator. When you get solar you will have a battery bank that can all be charged the same ways plus solar. Solar is an investment and a major upgrade. But it allows you be autonomous almost anywhere. That is priceless.
Just my thoughts.
flboy wrote:Transfer switch between the inverter and shore/gen and then to the AC circuits is needed unless you will be running separate AC circuits.
<snip>
Following are my schematics for reference only. I may have tweaked some DC breakers sizes since this drawing; however, the system functions great. Very happy with results.
I did not use an all in one panel for various reasons; however, functionally, it works the same way, just modular components to fit my specifics and customization.
<snip>
sodatrain wrote: I'm not planning on AC out of the gate... which makes me nervous. Only so much budget tho. I will have two fantastic fans.
Iconfabul8 wrote:sodatrain wrote: I'm not planning on AC out of the gate... which makes me nervous. Only so much budget tho. I will have two fantastic fans.
Not sure I follow the logic here. A window AC unit cost about the same as a fantastic fan. Why do you need two fans, rather than one fan and one AC unit?
Users browsing this forum: Bing [Bot] and 21 guests
