Aluminum composite teardrop
Re: Aluminum composite teardrop
Postby bobwhite215 » Sat Dec 16, 2017 5:17 pm
Got the driver's side door in today. Took a little longer than anticipated, so we'll have to get the other side tomorrow.ImageImageImage
Sent from my XT1585 using Tapatalk
bobwhite215
Postby bc toys » Sun Dec 17, 2017 9:55 am
thats one good looking trailer you have built yourself :D
bc toys
Images: 42
Postby bobwhite215 » Sat Jan 06, 2018 7:06 pm
The roof went on today. Used an old ACM sign that I had laying around. It was in good shape, so why not save a little money??
Here is the sign. We just vinyl wrapped the back side.
The ACM took the curve really well. Used some rachet straps to pull it down into place. The very front will be covered with aluminum diamond plate.ImageImageImageImageImage
bobwhite215
Postby greygoos » Sun Jan 07, 2018 7:54 am
Looks great. Thanks for the update.
greygoos
Postby bobwhite215 » Wed Jan 17, 2018 8:22 pm
Diamond plate installed on the front endImage
bobwhite215
Postby SLO_Ken » Fri Jan 19, 2018 7:18 pm
Is your ACM the solid core type, or the hollow core? How thick? I've been considering using ACM in place of plywood when I finally get around to building up my trailer. Seems like a fairly ideal material, if a little expensive upfront.
SLO_Ken
Postby bobwhite215 » Fri Jan 19, 2018 8:57 pm
SLO_Ken wrote:Is your ACM the solid core type, or the hollow core? How thick? I've been considering using ACM in place of plywood when I finally get around to building up my trailer. Seems like a fairly ideal material, if a little expensive upfront.
It's 3mm solid core. It bent really nicely along the roof. The corrugated core material would work well for walls, or if your roof is flat, but it will not bend well.
bobwhite215
Postby bnicho » Tue Feb 13, 2018 7:50 pm
Hi,
I have been following this thread with great interest, as I am also looking to use ACP in my build.
Where did you surce the router bits to use on the ACP? Are the bits special ACP bits or just standard wood or aluminium ones?
Thanks,
Brett
bnicho
Postby clamlamp » Sun Feb 25, 2018 10:31 am
I stumbled upon this build journal when you asked about the door install orientation. Great job! :applause:
clamlamp
Postby bobwhite215 » Sat Mar 31, 2018 6:43 pm
Have not had much of a chance to work in this for the past month, but spent some time today.
Got the inside galley walls finished out. Used 1/16" lexan, with the same pearl vinyl wrap that we used on the exterior. Held in place with vhb tape. Plan on getting it all trimmed out tomorrow, and then it's finally on to the galley door.Image
bobwhite215
Postby bobwhite215 » Sat Mar 31, 2018 6:44 pm
clamlamp wrote:I stumbled upon this build journal when you asked about the door install orientation. Great job! :applause:
Thank you. It's been a long process.
bobwhite215
Postby bobwhite215 » Sat Mar 31, 2018 9:16 pm
bnicho wrote:Hi,
Thanks,
Brett
Brett,
Sorry, just saw your post. I just used a regular wood bit.
Sent from my SM-T817V using Tapatalk
bobwhite215
Postby bobwhite215 » Sun Apr 01, 2018 5:47 pm
Today we got the roof vent fan installed and wired.
Also got the aluminum trim installed on both sides. The galley walls are now done and trimmed. I guess it's about time to start building that hatch I've been avoiding.ImageImage
bobwhite215
Postby Jeremy757 » Wed Apr 04, 2018 4:30 pm
Haha I’m at the same point in my build. I’ve been avoiding the hatch way too long.
Jeremy757
Postby bobwhite215 » Fri Apr 06, 2018 6:55 pm
Finished up some odds and ends this week.
The drip caps over the doors are in place.
Trim molding inserts and the galley hatch seals are in.
The trailer side of the galley door hinge is mounted.ImageImageImage
bobwhite215
