McDave wrote:Yup. That should work. You will want a pressure regulator at the city water input. Keeps ya from blowing a line and filling up the trailer while you are out fishing. I have one like this, you can spend more or less.
https://www.etrailer.com/RV-Fresh-Water ... 124VP.html
Welcome to the forum. Keep us posted on your progress. We like pictures![]()
McDave
Iconfabul8 wrote: The other thing is you probably don't need to tie your vents together. My fill inlet has the vent built in and the other tank would just need a baffle or riser with a filter of some sort. Flboy(Don) did his much like this, he can probably shed more light on the subject of dual tanks on opposite sides of the trailer.
Iconfabul8 wrote:I think he is pretty close. Two things I would bring up is: many RV water fill inlets have the check valve built in as do the pumps. So unless you want redundancy and some people do, you probably don't need check valves.
The other thing is you probably don't need to tie your vents together. My fill inlet has the vent built in and the other tank would just need a baffle or riser with a filter of some sort. Flboy(Don) did his much like this, he can probably shed more light on the subject of dual tanks on opposite sides of the trailer. Welcome to the Madnesslooking forward to your build!
troubleScottie wrote:Your tank fill may not work. Water may run out the vent prior to filling the opposite tank.
You need/should have drains somewhere. You can use the pump to drain the tanks, but values are easier. Also, the one way value might have to be moved to prevent prevent water being retained in the lines due to vacuum/airlock.
Not sure about the pump placement. My reading is that a pump can push water up to a specific height which is reasonably high, but may have difficulty lifting the water to the pump's level. You might want to have the pump lower.
Also you have no place for hot water -- although that is not necessary.
Hader wrote:Iconfabul8 wrote: The other thing is you probably don't need to tie your vents together. My fill inlet has the vent built in and the other tank would just need a baffle or riser with a filter of some sort. Flboy(Don) did his much like this, he can probably shed more light on the subject of dual tanks on opposite sides of the trailer.
I agree with Iconfabul8.
flboy wrote:Iconfabul8 wrote:I think he is pretty close. Two things I would bring up is: many RV water fill inlets have the check valve built in as do the pumps. So unless you want redundancy and some people do, you probably don't need check valves.
I did do saddle tanks over the wheels. They are each plumbed independent in terms of the fill and vents. I have a fill on each side with vent. One tank is the primary near the pump and distribution valves. The other tank just feeds into the output of the other at a "T" just before the pump. They both draw down at the same rate and will level themselves off automatically. So although what you have drawn may work, it is more complex than needed.
I can fill one tank full and in an hour or so they are both half full.. Likewise, I have the drain on one tank (primary) and they both drain. You only need one connection between the tanks under the trailer and that is the output of one to the output of the other just before the pump and only put a drain on one.
flboy wrote:Here is a napkin sketch. This is how I did it and it works great for me. You just have a gravity fill on both sides which includes a vent. Whatever side you choose, you also have the city water connection in the same panel as the gravity fill and vent. I have the one way valves and city water connection on the side with the pump.
Good luck.
rhelvey22 wrote:I have another question if y’all don’t mind.
Can we vent the black tank and the gray tank through the same outlet pipe?
