Exterior finishing for plywood
Postby lilgription » Tue May 29, 2018 7:22 am
Sorry if this is in the wrong section. I wasn’t sure where to ask this. What is the most common method for finishing plywood for the exterior if not skinning. Sealing + primer + epoxy paint ? Or ? Any help is appreciated
lilgription
Images: 27
Re: Exterior finishing for plywood
Postby Carl01234 » Tue May 29, 2018 9:10 am
On my 1rst build, I used white epoxy paint. It held up well until it sat uncovered outside for a few years.
2nd Build 5x10 Benroy Complete! viewtopic.php?f=50&t=70427
Carl01234
Images: 116
Postby tony.latham » Tue May 29, 2018 9:11 am
lilgription wrote:Sorry if this is in the wrong section. I wasn’t sure where to ask this. What is the most common method for finishing plywood for the exterior if not skinning. Sealing + primer + epoxy paint ? Or ? Any help is appreciated
I can't help you on your specific question, "most common." But you might take a look at this link:
http://www.tnttt.com/viewtopic.php?f=65&t=65559#p1163330
:thinking:
Postby John61CT » Tue May 29, 2018 2:00 pm
Glidden Gripper primer, thinned a bit for first few coats, really try to get full coverage, edges crannies much as possible, then at full strength, a couple more coats.
Then porch paint, color of your choice after that.
Or something glossy high tech if you want
John61CT
Postby lilgription » Tue May 29, 2018 4:37 pm
John61CT wrote:Glidden Gripper primer, thinned a bit for first few coats, really try to get full coverage, edges crannies much as possible, then at full strength, a couple more coats.
For the Glidden do you usually roll it on or spray ? I’m assuming roll to get full coverage
lilgription
Images: 27
Postby GPW » Wed May 30, 2018 4:35 am
We found "bent plywod” as on TD roofs for example tend to develop tension cracks after a while , which lets water in and then that’s the end of the roof … We ( many ) found that covering the plywood with a thin fabric ( canvas ), then painting, really helps prevent this and you can overlap the roof edges for more “waterproofing” …
Postby John61CT » Wed May 30, 2018 5:51 am
Roll and brush.
Gripper works great to glue canvas down as well, saturate the cloth before.
See TNTTT.com foamie section.
John61CT
Postby les45 » Wed May 30, 2018 9:23 am
I used Zinsser primer and Rustoleum on my weekender with 1/4" skins. Did a lot of prep work with fiberglass on all corners and joints and epoxy fillers in all the little cracks first. Rolled everything on with a 4" foam roller but make sure it is good for oil base paint. I rolled three coats of Rustoleum with the last coat diluted 25% with mineral spirits to give it a sprayed on look.
les45
Images: 605
Postby OP827 » Tue Jun 05, 2018 1:35 pm
I don't think it's possible to achieve reliable protection for plywood with any type of primer and paint without using fibers, either canvas and paint or fiberglass and paint, as they do in boats building. But that is just my opinion.
OP827
Images: 405
