Your 2nd teardrop is looking great!
I know the hardest part of my build was, not necessarily building the hatch, but trying to get my head right on how to build the hatch. At least for me, thinking in 3D is a challenge.
My approach was to think backwards. I used a 3/8" seal. As a general rule of thumb, you want to compress the seal about 1/3 of the way. This worked out to a 1/4" gap. This gap needs to be 1/4" all the way around the sidewall - 1/4" up and 1/4" out.
I wanted to keep the hatch profile on the same general profile of the teardrop sidewall. To do this, the outer edge of the hatch "ribs" matched the profile, but the sidewall was notched to create the gap. Here is a (poorly drawn) sketch of what I did:
The sidewall edge is the heavy black line. The hatch rib is shown with the blue lines.
The other option is to offset the hatch "out" from the sidewall profile. In this example, the hatch ribs need to extend the chosen gap distance beyond the sidewall. Here is a sketch of this approach:
If you go this route, you have to use an offset hinge,
and the ribs must be cut the gap distance beyond the profile.
If you use an offset hinge, but cut the ribs to match the profile, you'll have the desired gap at the hinge but you won't get the desired gap at the bottom of the hatch. The offset hinge will lift the ribs "up" but it won't lift the ribs "out". I believe this is the situation you are trying to work around.
In theory, you could use a thicker plywood "skin" on the hatch than on the roof to build out the hatch profile to the gap distance. However, the hatch is the last place you want additional weight, and adding more/thicker plywood will increase the chances of spring back in the hatch.
One solution to keeping your existing ribs and not notching the sidewall would be to add a "batten strip" beneath the hatch side of the t-molding and on top of the hatch skin to lift the sidewall side of the t-molding to the desired offset/gap.
