beachguy005 wrote:A problem with having the dealer cut the hole is it forces you to find something to fit the hole in that exact location. Not great if you have a design change later on. I think it's better to get the window squared away first and adapt the CT to it. Cutting through the roof is easy and the roof braces are likely 24" on center.
I think you maybe first. So you get to post the outcome.tc3 wrote:beachguy005 wrote:A problem with having the dealer cut the hole is it forces you to find something to fit the hole in that exact location. Not great if you have a design change later on. I think it's better to get the window squared away first and adapt the CT to it. Cutting through the roof is easy and the roof braces are likely 24" on center.
The dealer won't cut it, just add one or two extra supports near the future cutout hole. I'm mostly concerned with weatherability. Will literally just gluing a sheet protect the interior? How long before reapplication?
