My First Foamie
My First Foamie
Postby stharding1836 » Wed Jan 16, 2019 12:27 pm
I'm building my first foamie. I'm trying to build it to fit my family of five. It is on a 6.5'x9.5' trailer with a bunk bed in the front, a trundle bed underneath the bottom bunk, full size dinette bed, and the galley in the rear. I was originally going to build a square drop, but since the trailer will be wider than my truck I decided to change that to a teardrop because I didn't want to pull a wall. Wish me luck.
What I started with
Decided to change the shape
New Plan.jpg (52.85 KiB) Viewed 4596 times
Original plan long before I bought the trailer.
Original Plan.jpg (62.22 KiB) Viewed 4596 times
stharding1836
Re: My First Foamie
Postby stharding1836 » Wed Jan 16, 2019 12:30 pm
Making progress
I decided to use 1/4" OSB on the bottom of the trailer to hold the floor insulation in place
Undecked Floor.jpg (49.64 KiB) Viewed 4594 times
Floor Plan.jpg (57.65 KiB) Viewed 4594 times
stharding1836
Re: My First Foamie
Postby stharding1836 » Wed Jan 16, 2019 12:32 pm
More progress
The actual floor will be 19/32" OSB that will be covered with a laminate
Partially Decked Floor.jpg (67.45 KiB) Viewed 4591 times
I sealed the bottom with a roll of water and ice
Sealed Floor.jpg (48.54 KiB) Viewed 4591 times
stharding1836
Re: My First Foamie
Postby GPW » Wed Jan 16, 2019 4:56 pm
Water and Ice … ??? a “membrane" … ? :o
Re: My First Foamie
Postby stharding1836 » Thu Jan 17, 2019 6:23 am
GPW wrote:Water and Ice … ??? a “membrane" … ? :o
It’s a sticky tar paper for sealing the edge of a roof. I melted it to the trailer with a little hand torch.
stharding1836
Re: My First Foamie
Postby GPW » Thu Jan 17, 2019 1:10 pm
Oh Cool !!! Never tried that before … Hmmmm??? :thinking: ( more testing !!!) ;)
Re: My First Foamie
Postby stharding1836 » Tue Jan 22, 2019 9:09 am
GPW wrote:Oh Cool !!! Never tried that before … Hmmmm??? :thinking: ( more testing !!!) ;)
I think it should do well, especially once the weather warms up and it really seals to the wood.
stharding1836
Re: My First Foamie
Postby stharding1836 » Tue Jan 22, 2019 9:22 am
Finally got the floor bolted down and insulated. Now just finishing the decking. Those $5 OSB/Plywood circular saw blades are home depot are awesome.
stharding1836
Re: My First Foamie
Postby GPW » Wed Jan 23, 2019 7:47 am
ST , I’d think it would be a Great idea to really soak that OSB floor with “the Mix “ to absolutely waterproof it … From our recent experience , the waterproofing can greatly increase the durability and longevity of the OSB flooring … We didn’t use it on ours ( forgot and was in a rush) and 5 years later we had to replace the floor entirely … Had we waterproofed it , it would have been fine …
And also we’d HIGHLY RECOMMEND using some "drip edges” all around to keep any repetitive moisture off your flooring … :thumbsup:
Ps … the Mix is 75% common Mineral Spirits , and 25% Polyurethane Varnish … well proven , well worth the effort. ;) Soak it in till it won’t take any more … once treated, a water drop will just sit on top and evaporate , never even wetting the OSB … We treat ALL our wood with it now . 8)
Re: My First Foamie
Postby stharding1836 » Thu Jan 24, 2019 10:09 am
GPW wrote:ST , I’d think it would be a Great idea to really soak that OSB floor with “the Mix “ to absolutely waterproof it … From our recent experience , the waterproofing can greatly increase the durability and longevity of the OSB flooring … We didn’t use it on ours ( forgot and was in a rush) and 5 years later we had to replace the floor entirely … Had we waterproofed it , it would have been fine …
That's a good idea, thanks. :thumbsup:
stharding1836
Re: My First Foamie
Postby stharding1836 » Tue Feb 05, 2019 7:16 am
Got the bunk bed built
stharding1836
Re: My First Foamie
Postby stharding1836 » Wed Mar 27, 2019 7:31 am
I finished framing the dinette/queen size bed. I've decided to nix the galley since this is my first build. My next build won't be for a family of five, so I'll put a galley in that one.
Dinnette 3.jpg (91.75 KiB) Viewed 4102 times
Dinnette 2.jpg (86.11 KiB) Viewed 4102 times
Dinnette 1.jpg (62.29 KiB) Viewed 4102 times
stharding1836
Re: My First Foamie
Postby zzzizxz » Mon Apr 01, 2019 8:45 pm
How's this coming? Any new progress now that the weather is starting to turn warm?
zzzizxz
Images: 142
Re: My First Foamie
Postby stharding1836 » Fri Apr 05, 2019 11:35 am
zzzizxz wrote:How's this coming? Any new progress now that the weather is starting to turn warm?
It's still a little cold up here, but I decided to go away from that bulky bunk bed and build a new one out of 2x2s like the dinette, which I will finish this weekend and post some updates.
stharding1836
Re: My First Foamie
Postby stharding1836 » Thu Apr 11, 2019 8:23 am
Got some work done of the new bunk bed, and skinned the dinette.
Dinette skinned 3.jpg (81.58 KiB) Viewed 3908 times
New Bunk bed.jpg (73.66 KiB) Viewed 3908 times
stharding1836
