flboy wrote:I think a good coat of countertop paint to seal and protect. The you can take either 3/4" or 1/2" aluminum channel (depending on plywood thickness) to trim and finish and protect the edges. Following are a few pics of mine in process and finished if it helps. Maybe hard to see, but the edges of the countertop are trimmed with aluminum channel. I used 3/4" plywood for this.
halfdome, Danny wrote:Cover all of it (top & edges) with plastic laminate, it's less than 1/16" thick and water proof.Danny
atcNick wrote:flboy wrote:I think a good coat of countertop paint to seal and protect. The you can take either 3/4" or 1/2" aluminum channel (depending on plywood thickness) to trim and finish and protect the edges. Following are a few pics of mine in process and finished if it helps. Maybe hard to see, but the edges of the countertop are trimmed with aluminum channel. I used 3/4" plywood for this.
I really like this. How did you attach the aluminum? Is there a paint called “countertop paint”?
