Protecting plywood near sink?
Postby atcNick » Sat Feb 09, 2019 1:55 pm
I’ve got a build in table made out of plywood right next to the sink. Any suggestions on how to protect it? I’m afraid water from the sink may be absorbed at the edge of the plywood.
-Nick
atcNick
Re: Protecting plywood near sink?
Postby tony.latham » Sat Feb 09, 2019 2:59 pm
Epoxy.
I would suggest Raka's 127 thin. It'll soak deeply into the wood.
Postby halfdome, Danny » Sat Feb 09, 2019 5:20 pm
Cover all of it (top & edges) with plastic laminate, it's less than 1/16" thick and water proof.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby flboy » Sun Feb 10, 2019 5:16 pm
I think a good coat of countertop paint to seal and protect. The you can take either 3/4" or 1/2" aluminum channel (depending on plywood thickness) to trim and finish and protect the edges. Following are a few pics of mine in process and finished if it helps. Maybe hard to see, but the edges of the countertop are trimmed with aluminum channel. I used 3/4" plywood for this.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Postby Pmullen503 » Mon Feb 11, 2019 6:56 am
Leave an air gap of at least 1/8" between the sink and table top. Any water that gets in there can dry.
Pmullen503
Images: 67
Postby hankaye » Mon Feb 11, 2019 11:17 am
atcNick, Howdy;
All those fibrous ends, those exposed ends have voids and are extremely absorbent.
me, I'd use some oil based porch paint, stand it on end and allow the paint to soak
into the end grains until it creates a level surface then do the top and bottom.
OR, you can apply some Butyl-tape ( https://www.amazon.com/Dicor-BT-1834-1- ... B001FCB4JS ),
clamp the two surfaces together with pipe clamps, trim the excess that oozes out.
hank
hankaye
Postby atcNick » Mon Feb 11, 2019 12:37 pm
flboy wrote:I think a good coat of countertop paint to seal and protect. The you can take either 3/4" or 1/2" aluminum channel (depending on plywood thickness) to trim and finish and protect the edges. Following are a few pics of mine in process and finished if it helps. Maybe hard to see, but the edges of the countertop are trimmed with aluminum channel. I used 3/4" plywood for this.
I really like this. How did you attach the aluminum? Is there a paint called “countertop paint”?
-Nick
atcNick
halfdome, Danny wrote:Cover all of it (top & edges) with plastic laminate, it's less than 1/16" thick and water proof.
:D Danny
That is an option I’m considering
-Nick
atcNick
Postby flboy » Mon Feb 11, 2019 12:59 pm
Yes, there is countertop paint at HomeDepot or Lowes. It is an oil based acrylic paint. Water beads on it. You can see my sink and I get water all over it and no issues after 2 years. Seems very durable as well. It is called Rust-Oleum Countertop Coating and it is tintable to almost any color you want. I think it is meant to go over existing laminates, but I used directly on sanded furniture grade plywood. Use a Zinsser primer or Kilz primer first however and it will be fine.
I used liquid nails to glue the trim on, but it pressed on well to start with. You call also run a self taping screw in on the underside to hold. I did that while the Liquid Nail set up besides the fact I tend to overbuild. :-).
Good luck.
Don (Flboy)
flboy
Images: 378
