HandiCramper
Re: HandiCramper
Postby OP827 » Wed Jul 31, 2019 6:37 pm
twisted lines wrote:
OP827 wrote:Great work! Are you covering BB ply in epoxy with light glass cloth before finish?
I am not using epoxy, (polyurethane) Caulk then 3 coats of High Gloss then Monstraliner. To old and crippled up for Fiberglass.
I recall reports here of bedliner separation from plywood after sometime. Don't remember the build names though, sorry.
Sent from my Moto G Play using Tapatalk
I can picture a build or two, I only remember it was different brand's not monsterliner, Thank you for checking and making aware of possible flaws, I need can sure use guidance :thumbsup:
Nice build you have going.
Thanks, appreciate my build compliment. After I did a Google search over this site I found the post which was about Raptor bed liner over untreated Baltic birch plywood: http://www.tnttt.com/viewtopic.php?f=65&t=65559&start=15#p1245278. I would be interested to learn other people experience with urethane bed liners put on plywood without fibreglass after a few years of being outside. Do you know such builds?
OP827
Images: 414
Re: HandiCramper
Postby twisted lines » Wed Jul 31, 2019 9:28 pm
That is the one that stood out.
Here is one over glass. viewtopic.php?f=50&t=57065
Racking up; And Rapin foam
twisted lines
Re: HandiCramper
Postby OP827 » Thu Aug 01, 2019 12:31 pm
Yes, the covered in epoxy glass cloth did stand the test of time, the other one that had untreated plywood under a bed liner didn't. So you do not plan covering with glass before bed liner, but have plywood treated with some polyurethane, correct? I personally would go with glass before bed liner, but it is of course your choice. Let me know how it worked out. Cheers!
OP827
Images: 414
Re: HandiCramper
Postby twisted lines » Fri Aug 02, 2019 3:11 pm
OP827 wrote: So you do not plan covering with glass before bed liner, but have plywood treated with some polyurethane, correct?
YEP!
I am using a suggested method by what I consider a wise one. Using fiberglass and the suggested barriers are more time, money and labor;
Since I paid good money to have my heart stopped Wednesday can't say I have any of them. :o
Last shot before I glue the frame to the pod .
Steel to Aluminum (2).jpg (90.09 KiB) Viewed 5472 times
twisted lines
Re: HandiCramper
Postby twisted lines » Sat Aug 31, 2019 2:34 pm
Glued on and painted the frame; Scraping priming and painting the house :x makes her happy!
twisted lines
Re: HandiCramper
Postby OP827 » Thu Sep 19, 2019 1:21 pm
That sealant seam looks appropriate to eliminate galvanic corrosion. I must say that your workmanship is first class! Are you a fabricator by profession?
OP827
Images: 414
Re: HandiCramper
Postby twisted lines » Thu Sep 19, 2019 5:42 pm
OP827 wrote:That sealant seam looks appropriate to eliminate galvanic corrosion. I must say that your workmanship is first class! Are you a fabricator by profession?
Thank You.
The corrosion was a large part of the plan, And it is a very good Assembly Adhesive to boot.
I was for two fortune companies for 30 Years: But you won't be able to tell when I start the galley :oops:
twisted lines
Re: HandiCramper
Postby twisted lines » Fri Sep 27, 2019 4:19 pm
Started on my second layer of 1" foam, cutting a chanel for the wiring between the bottom layer and the finnished 1/8" ply to run wiring because the first layer had tubing in the way.
Finding I almost need to get the fan installed it's already getting hot and stuffy, but I am a long ways away from that.
Second layer.jpg (54.6 KiB) Viewed 5190 times
twisted lines
Re: HandiCramper
Postby twisted lines » Sun Nov 17, 2019 6:07 pm
Holding the 2" Insulation up; Good use for a teachers chair :lol:
The first curf that I snapped putting it up.
Tail light passage that I need to poke holes in
Adjustable Stand.jpg (76.29 KiB) Viewed 4923 times
Rear lights.jpg (75.45 KiB) Viewed 4923 times
Last edited by twisted lines on Mon Nov 18, 2019 10:34 am, edited 1 time in total.
twisted lines
Re: HandiCramper
Postby ricky herbold » Mon Nov 18, 2019 8:41 am
It’s looking great!
ricky herbold
Re: HandiCramper
Postby MickinOz » Tue Nov 19, 2019 12:43 am
So you used the Sikaflex 252?
How did you go getting it out of the caulking gun?
My tube is so stiff I'm considering an air operated gune.
MickinOz
Re: HandiCramper
Postby twisted lines » Tue Nov 19, 2019 11:04 am
ricky herbold wrote:It’s looking great!
Thank you!
MickinOz wrote:So you used the Sikaflex 252?
My tube is so stiff I'm considering an air operated gun.
I only used it in what I would call crucial areas, and did not squeeze it tight by using trimmer line between pieces.
The applicator First round was white fresh and warmed in the sun, it came out fine but was noticeably thicker then usual.
Second application was black and expired on arrival 6 months shelf life; (Didn't notice till second tube) warmed but did not use the application tips because I could not get it out.
I had bought a second cheap gun in case I broke the first, For the Frame job.
Make sure things are lined up very close when they touch and don't take you time moving (if you can)
I think there are battery operated guns as well, I like the cordless stuff.
twisted lines
Re: HandiCramper
Postby twisted lines » Sat Dec 14, 2019 1:41 pm
The dilemma of a few holes for racks :?
twisted lines
Re: HandiCramper
Postby OP827 » Sat Dec 14, 2019 4:05 pm
twisted lines wrote:The dilemma of a few holes for racks :?
If you are looking to build strong attachment points for a roof rack, maybe glue in some wood hard points in foam under the 1/8 plywood that you have and then epoxy in the threaded wood inserts like this:
https://www.amazon.ca/Z-Lok-Threaded-Hex-Flanged-Internal/dp/B002WC8TUW/ref=asc_df_B002WC8TUW/?tag=googleshopc0c-20&linkCode=df0&hvadid=292907900119&hvpos=1o1&hvnetw=g&hvrand=16967748812770145099&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1002392&hvtargid=pla-546946859687&psc=1
Several inserts for each each point should be able to distribute and take substantial load. Just a thought. The roof rack can be removable and plastic plugs can be inserted while the holes are not is use.
OP827
Images: 414
Re: HandiCramper
Postby twisted lines » Sat Dec 14, 2019 4:17 pm
Thanks for the link I will use the idea in two areas :thumbsup:
twisted lines
Users browsing this forum: azgreg and 9 guests
