My 100% garage built teardrop
Re: My 100% garage built teardrop
Postby ricky herbold » Tue Sep 10, 2019 9:40 pm
ricky herbold wrote:Picked up a couple of 6v batteries a was able to complete
The rest of the wiring in the tongue box today
ricky herbold
Postby ricky herbold » Tue Sep 10, 2019 9:45 pm
I finally found the correct poundage/length gas struts for the galley hatch. 5th set worked like a charm!
ricky herbold
Postby retep » Wed Sep 11, 2019 6:52 am
such a great build!!! Nice lines and very solid from the pics. Well Done.
May I ask which size and lbs of gas shock you went with?
Thanks
Peter
retep
Postby ricky herbold » Thu Sep 12, 2019 7:48 am
I ended up using one regular strut and one that locks in the extended position. The extension force is adjustable but I left them full force. 145lbs I believe. They hold it open fine and with the locking strut I will not have to worry about the hatch lowering in high winds. If you go with a locking strut, only install it on one side as you would need a third hand to unlock both struts and lower the hatch.
retep wrote:such a great build!!! Nice lines and very solid from the pics. Well Done.
Thanks
Peter
ricky herbold
Postby ricky herbold » Thu Sep 12, 2019 7:50 am
Thanks
Peter
ricky herbold
Postby retep » Thu Sep 12, 2019 8:18 am
Thank You Ricky. I like the locking idea, I was not aware that was a choice.
Again, excellent build. Well done.
Cheers
Peter
retep
Postby ricky herbold » Wed Sep 18, 2019 11:40 pm
Anyone have any recommendations/suggestions on a foam mattress? Build or buy. If I buy one I will need to cut it in half to be able to access the floor storage.
ricky herbold
Postby tony.latham » Thu Sep 19, 2019 10:44 am
ricky herbold wrote:Anyone have any recommendations/suggestions on a foam mattress? Build or buy. If I buy one I will need to cut it in half to be able to access the floor storage.
I've got a mattress sitting next to my new build. I'll stick it in this weekend. It's 5" of poly foam with a 3" memory topper. I've used these before and they are superb. Purchased from the Foam Factory.
https://www.thefoamfactory.com/mattress/memorymattress.html
Better than most motel beds. :thumbsup:
Postby Aguyfromohio » Thu Sep 19, 2019 1:02 pm
The mattress may be the most important item in a teardrop, the cabin is for sleeping.
The bed with mattress I installed does not please She Who Must Be Obeyed.
I had no idea I was living inside the story "The princess and the pea". Turns out I do live there, and she can still detect that dang pea.
:lol:
So my advice is to spare no expense on that mattress, it can save a lot of trouble if you get it right the first time.
Try it out, make sure you like the feel of it, buy a custom one if you need to.
I'm accumulating quite a collection of mattress pads and toppers and air mattresses....
Aguyfromohio
Images: 76
Postby ricky herbold » Sun Sep 22, 2019 9:39 am
That is too funny
:lol:
ricky herbold
Postby tony.latham » Sun Sep 22, 2019 9:51 am
Our new Foam factory 5" +3" memory mattress (with cover) is in the teardrop and it's just dreamy to lay on.
These things really need to be unwrapped inside the cabin. Trust me, I've done it both ways.
Postby ricky herbold » Sun Sep 22, 2019 8:55 pm
What lb memory foam do you recommend?
tony.latham wrote:Our new Foam factory 5" +3" memory mattress (with cover) is in the teardrop and it's just dreamy to lay on.
ricky herbold
Postby tony.latham » Sun Sep 22, 2019 10:20 pm
Scroll down to the Queen with 5" of medium base foam and 3" of 3 lb VicoSaver memory foam. They are superb.
If you go this route, make sure you buy the $10 cover. It comes installed. And open it inside the cabin.
Postby ricky herbold » Fri Oct 11, 2019 2:28 pm
Well, I finally got around to carpeting the ceiling and mounting the last 2 lights and beauty ring for the fan.
ricky herbold
Postby ricky herbold » Sat Oct 12, 2019 2:50 pm
Here is my under floor storage. It is 48 1/4” x 24 1/4” x 5”. Not sure what I will use it for but a little extra storage never hurts.
ricky herbold
