ricky herbold wrote:Picked up a couple of 6v batteries a was able to complete
The rest of the wiring in the tongue box today
retep wrote:such a great build!!! Nice lines and very solid from the pics. Well Done.
May I ask which size and lbs of gas shock you went with?
Thanks
Peter
Thanks
Peter
ricky herbold wrote:Anyone have any recommendations/suggestions on a foam mattress? Build or buy. If I buy one I will need to cut it in half to be able to access the floor storage.
Aguyfromohio wrote:ricky herbold wrote:Anyone have any recommendations/suggestions on a foam mattress? Build or buy. If I buy one I will need to cut it in half to be able to access the floor storage.
The mattress may be the most important item in a teardrop, the cabin is for sleeping.
The bed with mattress I installed does not please She Who Must Be Obeyed.
I had no idea I was living inside the story "The princess and the pea". Turns out I do live there, and she can still detect that dang pea.
So my advice is to spare no expense on that mattress, it can save a lot of trouble if you get it right the first time.
Try it out, make sure you like the feel of it, buy a custom one if you need to.
I'm accumulating quite a collection of mattress pads and toppers and air mattresses....
tony.latham wrote:Our new Foam factory 5" +3" memory mattress (with cover) is in the teardrop and it's just dreamy to lay on.
These things really need to be unwrapped inside the cabin. Trust me, I've done it both ways.
What lb memory foam do you recommend?
