by Stainless 2 » Tue Sep 17, 2019 6:30 am
Now that the cabin is closed in (windows are just held in temporarily by spring clamps inside), I needed to accommodate the only absolute that this project has. After much research, I had previously decided on this 5000 btu Energy Star certified Frigidaire window unit and framed accordingly. According to the mfg specs, the compressor ramps up in stages, and draws just over 700 watts for the compressor on start up. It has an economy setting that significantly lowers the power draw once the initial heat saturation has been removed. I framed out the surround with 2x4 lumber to increase the strength and stability of the mount. The universal support unit was found on Amazon, and works almost just as planned. Part of its' strength comes from the U channel shape of the main arm, so 2 small relief cuts into the 2x4 support allowed flush mounting of the support. I then slid the AC into the hole and shimmied it into place. I have approx 1/8" clearance around the sides and top of the AC unit that I will work on weatherproofing. I leveled the trailer first, then got the AC unit centered in the bubble. I attached the bottom leg triangulating the support by drilling through the rubber boot and through the metal "foot" inside and running a large exterior grade decking screw through to finalize the install.
My plan is to build a box to surround and protect the unit during transit. I have not reached a decision yet, but am leaning heavily to using aluminum angle and self perforated steel flashing (same as the wheel wells) front and sides on a hinge that will allow the cage to rotate up for clearance in case the perforations do not allow enough air flow for the unit to work correctly. I am also going to close in the condensate drain hole, and likely use a clear rubber tubing to direct the condensate to the bottom of the frame and away from the tongue box that I found by accident while searching for solar solutions for the trailer.
This box came from an oil field and had a small 50 watt BP panel installed onto it via a 2" square tube on an arm, and housed the battery and circuitry to operate a pretty complex set of solenoid operated valves. Unfortunately, these had been removed from the box. The man who listed it on craigslist was trying to sell the small solar panel, and the box was an afterthought. He was asking $100, and I told him that that was excessive for a 50 watt panel. Offered him a buck a watt ($50) and told him I wanted the box as well. He accepted, and now I have an excellent tongue box, and an extra solar panel that I dont know if I will use...LOL
The AC unit does a quick and efficient job of quickly cooling the cabin. The unit is pretty quiet, and I am very happy with it. I have a generator in mind that I will post up on in fairly short order.
- Attachments
- 20190811_125217.jpg (49.94 KiB) Viewed 2813 times
- 20190811_125151.jpg (51.03 KiB) Viewed 2813 times
- 20190811_125145.jpg (48.09 KiB) Viewed 2813 times
