HF welding machine ???
Re: HF welding machine ???
Postby GPW » Thu Oct 10, 2019 5:28 pm
Tony , Thanks Once again !!! :thumbsup: 8)
Postby Modstock » Thu Oct 10, 2019 8:12 pm
I just saw a hack for that using a 2lb spool cut in half. Awesome.
Sent from my H1611 using Tapatalk
Modstock
Postby swoody126 » Fri Oct 11, 2019 8:01 am
by regluarly perusing CL i found a Lincoln 180(220v) just yesterday NIB
and @ the spry young age of 71 brought it home for $400
by time to close the barn doors yesterday evening it was assembled and passing nice welds on 1/4" structural steel scraps using .035 flux core wire(outdoors in a breeze) and set in the middlish portions on the 2 dials(amperage & wire speed)
never could find a 120v unit worth a tinker's dam
buy once cry once(i learned the hard/$$$ way and i now have a 120v Miller for sale REAL CHEAP)
sw
swoody126
Postby Squigie » Fri Oct 11, 2019 11:41 am
swoody126 wrote:by regluarly perusing CL i found a Lincoln 180(220v) just yesterday NIB
sw
In the 'budget' world, where fine adjustment is rare:
If you're welding structural components, and especially 1/4" or thicker, a 220V machine is pretty much mandatory.
But if your priority is sheet metal and/or autobody work, the 110V machines usually allow for a little more 'finesse' and softer start.
Different strokes for different folks.
I'm still looking for the right 220V multi-process machine for myself; as well as a set of O/A bottles (I have half a dozen torches and regulators, but no bottles of my own). But I won't be ditching the little 110V machine. It is so much easier to work with for sheet metal and thin-walled structural tubing that I want to keep it around. (I missed a good opportunity on an engine-driven multi-process last year. Still kicking myself for procrastinating...)
In the aircraft world, weld processes are a hot topic - especially for amateur repair and home-built steel frames.
Most people today think TiG is best, because of the control and cleanliness afforded by the process.
Others think MiG is the best, because you just pour wire into the joint and grind the excess.
Only the most experienced and/or old-school guys bring up O/A welding ... because they don't want to have to explain it to the guys that grew up with everything in their lives relying on electricity. They know that, even though it's a dirtier process with arguable less precise control than TiG, it's still more controllable than MiG and has a very important byproduct: Stress relief. The method of heat application and minimal use of filler rod results in joints with far less stress than TiG or MiG. The process is almost 'self-annealing', so to speak. That can be a very big deal, especially with assemblies like the infamous "five point" in the tail of a J-3 Cub (the joints of which, coincidentally, are nearly impossible to reach with a MiG torch and almost as difficult to get at with a TiG torch).
If you really want an interesting discussion, ask an old aircraft builder about O/H welding (Oxygen/Hydrogen). People today think it's garbage, even though they've never seen it, let alone tried it (including myself). The old guys say ignorance is bliss...
What's right? What's wrong? What's my point?
They all work. They all have their place.
Some are easier to work with. Some are easier to learn. Some require less (or zero) touch-up. Some require less prep. Some result in a better end product.
You can't have 'em all. Pick what you want and find the weld process that ticks your chosen boxes.
(An astute observer may have noticed that stick welding [SMAW] was not mentioned in aircraft frame welding. That's because aircraft frames are so thin that attempts to use stick usually blow right through the tubing/gusset/bracket. I know of no one that thinks stick welding is a good idea for aircraft - not even the guys that have done it.)
Squigie
Postby RJ Howell » Fri Oct 11, 2019 11:42 am
While we're on this line of welding, Might I ask another.
I have a line on a Hobart Handler 120 and looks in pretty good shape. The guy has been very honest and up front (someone we rarely see now a days) and mentioned that for the aluminum welding I hope to do I'd want the hand feed gun vs. the core feed (hope I termed those close enough..). He also said one is not made for the Hobart 120 Handler.
How much of a deal killer is this?
I have quite a bit of aluminum in the shop I've collected over the years and use for. As I look into a welder, I've chosen to go MIG so I can use my aluminum.
I'm at $150 now for the welder. Tips, new sleeve, roll of flux core and a few other little items. I'd have to by a tank and a auto shielding helmet. Welder is 20yrs old I figure, went out of production in 1999 (?) I believe. Looks like it's 3yrs old.
Thoughts?
RJ Howell
Images: 36
Postby Squigie » Fri Oct 11, 2019 11:50 am
It's possible to rig a spool gun up to just about any machine, but life is better if it's just a plug-and-play situation.
You definitely want a spool gun. Aluminum wire doesn't like being pushed through long liners, and any contamination in the liner is going to ruin the welds, anyway.
Philip wrote: Another reason I am saying 140 amp. Most of them run .035 wire. That I the easiest wire to find. If you get one using .020 or .025. A lot of places might sell the welder. But they do not sell the wire for it.
Aye.
I run 0.023" wire with gas (C25). Cheap, nasty wire is available in a fair number of places, but I got a bunch for free after I bought my machine and had enough problems that I gave it all away.
There's one welding supply place near me that sometimes has some 0.023" wire of decent quality. Otherwise, I have to order online and have it shipped.
Whatever wire size you're running, be sure to stock up.
Running out of wire is worse than running out of gas. You can weld without gas, but not without wire.
Squigie
Postby twisted lines » Fri Oct 11, 2019 12:51 pm
RJ Howell wrote:How much of a deal killer is this? Thoughts?
Quick summary, The welding helmet is the only thing on your list to help you weld aluminum.
Racking up; And Rapin foam
twisted lines
Postby NevadaBlue » Fri Oct 11, 2019 6:57 pm
Let someone else weld the aluminum.
So, for thin steel, an ordinary acetylene torch works fine. It is very much like using a TIG actually. I learned to weld auto body type metal with a torch and never looked back. I did buy the TIG for gun work, but it wasn’t really necessary. If you can torch weld, you can tig weld.
‘Bring it over, and I’ll weld up what you need.
:beer:
Ken
NevadaBlue
Postby PCO6 » Sat Oct 12, 2019 5:34 am
NevadaBlue wrote:Let someone else weld the aluminum.
:beer:
I learned to weld using an O/A torch too. I agree that it helps with learning tig and almost every other type of welding. I weld mostly with my Lincoln 180 mig welder now but still often use my torches. I used to do a lot of hammer welding without using filler rod … basically fusing 2 sheet metal panels together. Once you get the hang of it it can be done fairly quickly and it's very satisfying. The main purpose of using this method is that you can run the finished panel through an English wheel without damaging the anvils. Steel filler rod would nick the wheels badly and simply isn't done by anyone.
PCO6
Postby swoody126 » Sat Oct 12, 2019 6:42 am
Squigie wrote:...
i didn't know aircraft welders used O/H butt makes sense
the only O/H welding i've done is on GLASS(Pyrex & Quartz in the milk production industry and university scientific research labs)
the reasoning behind it(absodadgumlutely CLEAN WELDS) is paramount in both industries
didinium(¿sp/pronunciation?) glasses are hard to find @ regular welding supply stores ;-)
sw
swoody126
Postby GPW » Sun Oct 13, 2019 5:39 am
We went to HF yesterday and got a few things we’d need … They had everything except the welding machine we specifically went there to buy ( grrrr!!! ) So I told them , I’m paying for it now , and at the sale price , and call me when it gets in ( next truck ) ... They agreed :o … And while there I picked up a few things on Sale and a few things that weren't … All things I “needed” … We’re ready …. almost …
And while I was out I VOTED !!! ;)
HFtools .jpg (148.56 KiB) Viewed 3058 times
Postby KTM_Guy » Sun Oct 13, 2019 10:28 pm
If you have a Lincoln Tombstone welder you can add a TIG torch for about $100 and an argon cylinder another $100ish and have scratch start TIG. :thumbsup:
Todd
KTM_Guy
Images: 193
Postby GPW » Mon Oct 14, 2019 5:06 am
Todd, Really ?? :o
Postby KTM_Guy » Mon Oct 14, 2019 12:42 pm
Yup, add a high frequency unit and you can weld aluminum. Won’t be as good as a dedicated TIG but it works. One of the reasons those old stick AC/DC welders are holding some value. Spend some time on Google or YouTube tons of info out there.
Todd
KTM_Guy
Images: 193
Postby RJ Howell » Mon Oct 14, 2019 1:25 pm
KTM_Guy wrote:Yup, add a high frequency unit and you can weld aluminum. Won’t be as good as a dedicated TIG but it works. One of the reasons those old stick AC/DC welders are holding some value. Spend some time on Google or YouTube tons of info out there.
Todd
Todd, I'm assuming if the Tombstone is labeled AC, this wouldn't work??? Has to be a AC/DC unit??
RJ Howell
Images: 36
